BUilding a new road, culvert suggestions?
   / BUilding a new road, culvert suggestions? #51
We had some timber cutters in the area, about 10 years ago... They needed to cross a small creek. For a temporary culvert, they cut an approx. 30" hollow Beech tree, and used it for a culvert...
One of our bridge inspectors checking bridges in the area snapped a couple pictures of it... Wish I had the pics now....
Good old Yankee enginuity..!! LOL...
   / BUilding a new road, culvert suggestions? #52
I have seen culverts built out of trees, 2 large ones laid about 4' apart, a bunch of 8 footers spanning the gap, with a bunch more long ones laid over the top sort of like a cordroy road, then the whole thing covered with gravel. Has worked for many years on logging roads in Maine. Some of these trucks are hauling 20 cords per trailer and hauling double trailers. I personally know the Pellatier's (American Logger) they have some yankee Ingenuity.
   / BUilding a new road, culvert suggestions? #53
Hi Neighbor,
I enjoyed the Pelletier's segments on American Logger. Don't think I would want to be a log truck driver :eek:, or an Ice Road trucker either.
I checked out your web site, nice farm you have there.
Where in Skowhegan is the Farmer's Market? I would be coming from the Madison direction.
Dave.
   / BUilding a new road, culvert suggestions? #54
I have seen in "Farm Show" magazine where people have taken old tires and bolted them togther through the sidewalls with bolts and washers in order to make cheap culverts.
In this case, several old semi tires bolted together just might be large enough and should produce a very durable culvert if it has 10 inches or so of dirt on top of it. I am guessing that the tires could be obtained for essentialy free and the only expense would be minimal for a few bolts and washers and better yet no special tools are even required for the assembly as almost everyone has a drill of some kind.
   / BUilding a new road, culvert suggestions? #55
Hi Neighbor,
Dave.
They are deffinatelly a different breed up there!
The Farmers Market is right on 201 at the intersection near Hights Chevrolet.
We (my wife) will be there this weekend the 31st but we are only there once a month. Next year we will be there every weekend.
   / BUilding a new road, culvert suggestions? #56
Great, hope I make it. Thanks,
Dave.
   / BUilding a new road, culvert suggestions? #57
It's ipossible to estimate what size pipe will work for you without seeing our place and knowing your conditions. I live in an area that gets heavy rains, with 2 inches in an hour not being uncommon, and 5 inch rains in a few hours happening about every other year. That much water on the ground creats allot of runoff. I have a field that's about 8 acres of grass, and another ten acres fo woods that works it's way to the grass. That all goes through a 15 inch culvert, but on extreme rains, I've seen where it's maxed out for brief periods of time. The water has never gone over the road, but it's filled up that pipe to the point it was pooling up.
My 18 inch culvert, and I only have the one, is down hill from that 15 inch pipe. Even though it's only 3 inches larger, it handles twice the volume, or more, then the smaller pipe. It gets more water from other areas then the pipe above it, plus the water from that pipe, and it's never come close to maxing out.
Hope this helps,
Eddie[/QUOTE
I've been at my place since 1983. I have 3 water crossings. Higher up hill have one 18 inch corrugated aluminum. On down have 2 18 inch plastic culverts in two crossings. Before 2007 I had one 24 concrete culvert for each crossing. No problems with with water, except rare clogging with branches and leaves. In 07 gas well folks remolded driveway tearing up concrete and replacing with 2 18 in plastic. Branches and leaves last 2 years and once 5 yr ago. In my area we had record rain 3 times since 1895. 1895 was 4th highest ever. First I toyed with replacing 18s with 24s. As I think through, MY problems were massive rain causing lot of branches, gravel & rocks fully blocking culverts. Now I think I need to stop the debris from filling pipes. I thought maybe I could put a dam about 30 feet before each culvert. Thus when the big washing out rain comes the rocks branches etc get caught at a catch point. Dam or fence? Then have a hoe empty debris? when convent.
How does that sound??
Cheers to all.......Coffeeman
   / BUilding a new road, culvert suggestions? #58
Trash racks are very effective for high intermediate flows. Having a large culvert plug up can cause a lot of expensive damage to your road and are extremely dangerous to try to unclog.
Knew of the road foreman for the road construction and maintenance crew for Georgia Pacific in NW Washington. Went into a clogged 36" (?) Culvert to place a charge to clear it. Pulled on a stick to make room for the dynamite. Clog let go and shot him down the mountain side. He woke up several days later in the hospital for a several week stay.
At least he didn't send a subordinate in.
   / BUilding a new road, culvert suggestions? #59
I've never heard the term "Trash Rack" before, but I've seen what I guess is a trash rack before culverts that where clogged up with branches and leaves. If I was to do this, I would probably make it ten feet in front of the culvert to catch branches by driving rebar, or pipe, into the ground every six inches apart. Leaves wont cause too much problems if there isn't any branches. Stopping branches from blocking the entrance to the culvert, or getting into it should eliminate all the issues.
   / BUilding a new road, culvert suggestions? #60
2019 Bobcat 3400 4x4 Utility Cart (A55851)
2019 Bobcat 3400...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
24" Wain Roy Bucket (A50775)
24" Wain Roy...
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
PALLET OF 2" X 4" STEEL TUBING & SITE PANELS (A54757)
PALLET OF 2" X 4"...
JOHN DEERE 7130 TRACTOR (A51406)
JOHN DEERE 7130...
