DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,597
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
You may check around, and see if there is any natural gas pipeline in your area. Sometimes they replace sections amounting to thousands of feet. I bought approx. 100' of 20", several years back, for $2.00 per foot. It is 3/16" thick.. The bowed pieces where they pulled out, and held up to cut, come in handy for ravines with a slight curve... Great stuff..!! Also tubular piling left over from construction projects...
Large culverts can be made from old underground fuel storage tanks also. Cutting the ends out are iffy though...
Also around gravel pits, or power plants that use coal, or coal wash plants... Some use large diamenter polyethylene pipe, with 2" walls. What they consider worn, is plenty good for culverts.. We ran loaded single, and tandem trucks with 18 to 24" cover, and didn't distort them...
