building a fel
/ building a fel #1
dennisthomas
Troy, Oh
John Deere 755
i was thinking about building a fel for my John Deere 755. i wanted to make it a quick detach. has anyone attempted or have any type of plans for this? any help would be greatly appreciated.
/ building a fel #2
Most of the plans I have seen don't have a quick detach design. I really like the JD loaders with the way they detach using the forward links to the bumper as a stand. It's a very clever design. If I were you, I would get some plans and then modify for a quick detach. You wouldn't have to make it as complicated with the release mechanism as the JD.
/ building a fel #3
Dennis,
Wouldn't it be a lot easier/cheaper to just buy the loader? I believe the 755 takes the model 70 loader. It takes about 1-2 minutes to install or remove.
Brian
/ building a fel #4
I built the CadPlans 907 for my FX24D. It would be relatively easy to modify for quick disconnect. It is already set up for quick detach from the tractor.
/ building a fel
i tried looking at the link but no luck.
/ building a fel #8
Looking @ the Pictures, it looks as if it has a leg under it to hold it in postition, and a Pin back @ the attachment point and it all comes off... It is a good design and looks similar to the attachment on My Case loader.
When you raise and loader does the Bucket move forward?
I really like the way it Tips so far back, and puts the load over the pins, that must increase lift capacity a bit. A little orange paint and it'll look better than factory. /forums/images/graemlins/smile.gif
I'll attach a pic of my facotry made loader off the tractor, it seems to be one of the better QA designs, and it takes me only 2 minutes to detach, and slightly more, 3-4, to attach.
Ken
/ building a fel #9
Yep, it has an articulating bucket...it will maintain the bucket position throughout the lifting cycle. I just looked at a lot of bigger tractors and basically copied their design. I will say that it took a lot of effort on my part to come up with all the pivot points and linkages, etc. I also copied the Kubota method of attaching the loader to the tractor.....and the control valve stays with the tractor, kinda like the Green ones.
/ building a fel
that is a nice looking loader thanks for the pics. you designed it yourself im taking it. i like the quick detach. did you just base it off another loader? it looks like you used rectangular tubing for the arms. did you cut it out to taper it? i would like to see a few more detailed pictures of the loader attach and links if possible
60in. Work Bench (A65640)
60in. Work Bench...
2018 CATERPILLAR 320 EXCAVATOR (A65053)
2018 CATERPILLAR...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
2016 Ford Transit 350 Enclosed Service Van (A64556)
2016 Ford Transit...
2006 Chevrolet TrailBlazer SUV (A64557)
2006 Chevrolet...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
