Bucket Will not Curl
/ Bucket Will not Curl #1
chiselhead
umatilla
ford 1920/ 7108loader
Hi Guys Im New To The Site.I Have A Ford Model 1920 With A 7108 Loader.This Weekend I Was Moving Some Dirt,I Dumped A Load And Tryed To Curl The Bucket Back And Nothing Happened.It Sounded Like It Put A Strain On The Motor.HD Oil Was Alittle Low So I Topped It Off.Still No Curl.I Have Had It For About 5Years,Have Never Checked The Filter Screen And Dont No Where It Is Located.Any Help Would Be Appreciated.
/ Bucket Will not Curl #2
double check any quick-connects attaching the FEL, best to uncouple, clean and reconnect
/ Bucket Will not Curl #3
Sounds like its a little shy in the routine maintenance department. Have you lubed the loader arms, pivot points, etc?
Thanks For The Info,After Reading Alot Of The Posts That Seems To Be A Common Problem,And Come To Think Off It I Did Push A Pile Off Brush The Day Before And My Grill Looks Like It Took A Pretty Good Hit From Something.I Will Disconnect And Check Them Out.
Yes Sir I Was A Machinist For 25yrs.Took All Grease Fittings Out Cleaned Old Grease Out Of Holes.Just Repacked Both Lift Cylinders And One Bucket Cylinder.Do You Know Where The Hyd.Screen Is Located.
/ Bucket Will not Curl #6
after checking qd's.. pull return side hose off the curl cyl and see if it is bypassing
I Did Not Take The Hoses All The Way, But I Did Crack Each Of Them Open And Had Fluid.One Did Have More Pressure On It Shot Out Pretty Good The Others K ind Of Just Ozzed Out.
2005 SBX-5 60in. Box Blade Tractor Attachment (A61572)
2005 SBX-5 60in...
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
SINGLE BOTTOM PLOW (A64280)
SINGLE BOTTOM PLOW...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
