Bucket Will not Curl
/ Bucket Will not Curl #1
chiselhead
umatilla
ford 1920/ 7108loader
Hi Guys Im New To The Site.I Have A Ford Model 1920 With A 7108 Loader.This Weekend I Was Moving Some Dirt,I Dumped A Load And Tryed To Curl The Bucket Back And Nothing Happened.It Sounded Like It Put A Strain On The Motor.HD Oil Was Alittle Low So I Topped It Off.Still No Curl.I Have Had It For About 5Years,Have Never Checked The Filter Screen And Dont No Where It Is Located.Any Help Would Be Appreciated.
/ Bucket Will not Curl #2
double check any quick-connects attaching the FEL, best to uncouple, clean and reconnect
/ Bucket Will not Curl #3
Sounds like its a little shy in the routine maintenance department. Have you lubed the loader arms, pivot points, etc?
Thanks For The Info,After Reading Alot Of The Posts That Seems To Be A Common Problem,And Come To Think Off It I Did Push A Pile Off Brush The Day Before And My Grill Looks Like It Took A Pretty Good Hit From Something.I Will Disconnect And Check Them Out.
Yes Sir I Was A Machinist For 25yrs.Took All Grease Fittings Out Cleaned Old Grease Out Of Holes.Just Repacked Both Lift Cylinders And One Bucket Cylinder.Do You Know Where The Hyd.Screen Is Located.
/ Bucket Will not Curl #6
after checking qd's.. pull return side hose off the curl cyl and see if it is bypassing
I Did Not Take The Hoses All The Way, But I Did Crack Each Of Them Open And Had Fluid.One Did Have More Pressure On It Shot Out Pretty Good The Others K ind Of Just Ozzed Out.
2019 UTILITY VS2DX 53' X 102" T/A VAN TRAILER (A59912)
2019 UTILITY VS2DX...
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
UNUSED ATSPOWER ELECTRIC WINCH (A64281)
UNUSED ATSPOWER...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
(2) UNUSED 15-19.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 15-19.5...
2017 Ford Fusion SE Hybrid Sedan (A61574)
2017 Ford Fusion...
