Bucket Will not Curl
/ Bucket Will not Curl #1
chiselhead
umatilla
ford 1920/ 7108loader
Hi Guys Im New To The Site.I Have A Ford Model 1920 With A 7108 Loader.This Weekend I Was Moving Some Dirt,I Dumped A Load And Tryed To Curl The Bucket Back And Nothing Happened.It Sounded Like It Put A Strain On The Motor.HD Oil Was Alittle Low So I Topped It Off.Still No Curl.I Have Had It For About 5Years,Have Never Checked The Filter Screen And Dont No Where It Is Located.Any Help Would Be Appreciated.
/ Bucket Will not Curl #2
double check any quick-connects attaching the FEL, best to uncouple, clean and reconnect
/ Bucket Will not Curl #3
Sounds like its a little shy in the routine maintenance department. Have you lubed the loader arms, pivot points, etc?
Thanks For The Info,After Reading Alot Of The Posts That Seems To Be A Common Problem,And Come To Think Off It I Did Push A Pile Off Brush The Day Before And My Grill Looks Like It Took A Pretty Good Hit From Something.I Will Disconnect And Check Them Out.
Yes Sir I Was A Machinist For 25yrs.Took All Grease Fittings Out Cleaned Old Grease Out Of Holes.Just Repacked Both Lift Cylinders And One Bucket Cylinder.Do You Know Where The Hyd.Screen Is Located.
/ Bucket Will not Curl #6
after checking qd's.. pull return side hose off the curl cyl and see if it is bypassing
I Did Not Take The Hoses All The Way, But I Did Crack Each Of Them Open And Had Fluid.One Did Have More Pressure On It Shot Out Pretty Good The Others K ind Of Just Ozzed Out.
2015 FREIGHTLINER CASCADIA ROAD TRACTOR (A62130)
2015 FREIGHTLINER...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
Kubota KX057-4 Excavator (A61166)
Kubota KX057-4...
Bradco 84in Hydraulic 6-way Dozer Blade Skid Steer Attachment (A61567)
Bradco 84in...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
2012 Toyota Avalon Sedan (A61569)
2012 Toyota Avalon...
