Bucket lights?
/ Bucket lights? #21
Rear lights for snowblowing and backhoe use.
/ Bucket lights? #22
YeeHaww, another guy from Nova Scotia !! Looks like you made a trip to Princess Auto for your rear lights, they look just like mine /forums/images/graemlins/smile.gif I notice you've chain hanging from your loader frame; how about a close up pic to show us how you've got that done.
Eric
/ Bucket lights? #23
The bracket is UMHF (at least I think those were the initials), the box is 1/8" plate. I didn't weld it tight so the water would drain out. Bracket is just sitting there hooked over bolt. Holds two lengths of chain ten feet long.
Steve
/ Bucket lights? #26
Bob,
I visited the sight and found a couple of waterproof switches, but could not find the modular bezels for mounting /forums/images/graemlins/confused.gif. I like the look of yours mounted on the fender and wanted to change mine. I plan to add an outlet for hand-held lights so I'll end up with three switches. I currently have my switches under the dash. Can you offer any help finding the bezels on the web site (?part #).
/ Bucket lights? #27
<font color="blue"> .......but could not find the modular bezels for mounting </font>
16187F - Black Modular Bracket Rocker Switch
Don
/ Bucket lights? #28
Well, this thread woulda been helpful about a month ago.
I ended up ordering a waterproof, dustproof Cole Hersey rocker switch from a local auto parts store for $10.50. But it took me a few weeks to track it down. I put it in the location that was set up for the auto 4x4 switch, so all I had to do was pull out the plastic plug and snap it in the hole.
For those of you that only need 1 switch, check some of the local auto parts stores first, as some of them can order in anything from their suppliers, even if it's an item they never stock.
So, I have a question for everyone that's already wired extra lights. Being a little lazy, I took the easy way out, and ran the power wire directly to the battery, instead of wiring it into the headlight switch. What's nice is that I can turn the lights on without the key. But I'm wondering if anyone else has done that, and then accidentally left the switch on and killed the battery. I figure as long as I'm thorough when shutting down, no problems, but all it takes is just one time forgetting, or one of the kids playing with the switches, and presto, I go out to find a dead battery. I kind of figured I'd wait until I kill the battery before I pull out the soldering iron and wire it up the right way. /forums/images/graemlins/blush.gif
/ Bucket lights? #29
Bandit . . . I took the easier way out and only went to the alternator stub instead of going all the way up to the battery. But I used lighted switches because I wanted visual confirmation that the switch was off.
/ Bucket lights? #30
Hi, I ran 2 20 amp fused circuits from the battery and 1 is a spare for future use. I used lighted switches, 2 underneath my headlight switch, its pretty hard to hit them accidentally. However, a kitty cat /forums/images/graemlins/crazy.gif or a playfull child might do me in one day. I could always put a relay in the circuits and controll it by the light or ignition switch, but I'll wait untill something happens. Just a thought, how about lights on the top of the bucket itself mounted in a square or round tubing for protection? Any thoughts anyone?
/ Bucket lights? #31
Thanks Don. Guess I was "trying too hard" to search the site. All I needed to do was use the link you sent earlier - duh /forums/images/graemlins/crazy.gif
/ Bucket lights? #32
Oops, I forgot, I too ran the wire to the alternator stub - I was going to run it to the battery, but I changed my mind once I started, and took the easier route. /forums/images/graemlins/cool.gif
Sounds like I'm not the only one that was too lazy to tap into the headlight switch, and avoid an accidental battery draining situation in the future. /forums/images/graemlins/grin.gif
2001 MACK VISION DUMP TRUCK (INOPERABLE) (A67714)
2001 MACK VISION...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2010 CATERPILLAR 312D EXCAVATOR (A65056)
2010 CATERPILLAR...
2013 WACKER NEUSON  TLN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2017 Ford E-450 Super Duty Shuttle Bus (A66736)
2017 Ford E-450...
