Bucket hooks
/ Bucket hooks #1
Hughman
Platinum Member
La Grange, CA
NH TC33DA
/ Bucket hooks #4
Nope, you want the blue ones. You did good. I got Red ones since my tractor is red. I need to install some on my MILs tractor, already have them bought.
/ Bucket hooks #5
Black ones cost $39.99........same with John Deere green or Kubota Orange (they know money is no object with those guys! :) )
Blue, red same hooks $23.99, 1/2 the price.
/ Bucket hooks #13
Got to be at least 10 thread already on installing bucket/chain hooks..... I oped for home made...
slots-3-jpg.577844
Those are cool! And home made. Real fabrication deserves a thread, not a $23.99 hook set and drilling 4 holes.
nice design!
/ Bucket hooks #15
Am I the only one that wants hooks down low on back of bucket much closer to the tractor ?
so much better for lifting heavy objects imo
Nice work there. One thing I like about hooks on the top of the bucket is the ability to pull up on the chain using the bucket curl.
/ Bucket hooks #16
They would have to be welded on as you did or the bolt heads could cause material to stick in the bucket.
/ Bucket hooks #18
No, mine is on the back of the bucket. Used an existing hole:
Flips up for over the front:
/ Bucket hooks #19
The back of JD OEM buckets are double walled
/ Bucket hooks #20
Then welding is the only option on the back of that JD bucket. No way would you want to drill & bolt thru both walls.
2005 International 9200 Semi Truck (A66285)
2005 International...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
250 gal Livestock Lick Tank (A66408)
250 gal Livestock...
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
2012 Great Dane 53' Van Trailer (A66285)
2012 Great Dane...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
