Loader Bucket hooks
/ Bucket hooks #1
Engine Mike
Rochester hills michigan
Kubota B2320
I have a new 4WD Kubota B 23 HP 2320 with loader. Great machine. Does anyone have advice on installing hooks on the bucket to help lift heavy objects?
/ Bucket hooks #2
You could have chain hooks welded on or you could get some bolt on hooks. Mine are welded on. Kens Bolt ON Hooks is a good source of bolt on hooks and he sells the weld on hooks too.
/ Bucket hooks #3
mount them inline with your loader arms.
/ Bucket hooks #4
Get some Weld on hooks, put them in line with the loader arms, and reinforce the top lip of the bucket if needed with an L shaped bracket to keep if from being compressed or extended. On the Kubota bucket shown, I put a piece of steel that goes the entire length. but on the Kioti bucket it was already supported, and a pad was already provided to weld the hooks too.
James K0UA
/ Bucket hooks #7
Ok thanks guys. Some say to add 3. Two in line with the arms and 1 in the middle. Agree?
Thats good, or what some do is add a 2 inch receiver and then you can put a hook, a ring or the anchor for a boom pole, or any number of other things in the center. Anything you can think of that will fit a 2 inch receiver can be put on in a few seconds.
James K0UA
/ Bucket hooks #9
I agree with k0ua. Put a 2 inch receiver tube in the middle. I keep a GN hitch ball mount in mine. A boom pole can also go in that spot for hanging trusses. Or you can leave a hook in the tube. When am lifting a really heavy object, I just wrap the chain around the 2 inch receiver tube and ball mount.
This AFTER I welded a 3/8th inch thick angle iron across the whole span of the top lip.
hugs, Brandi
/ Bucket hooks #10
I say 2 hooks is perfect since you only have a 48" bucket I think, lift capacity is about 600-800lbs IIRC.
/ Bucket hooks #12
Here is what I did on my B3030. The hooks on the far corners were welded on when I bought the tractor. Messicks of PA installed them at this location.
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
2008 GENIE Z-45/25 TELESCOPIC BOOM LIFT (A65056)
2008 GENIE Z-45/25...
2017 JAYCO WHITE HAWK CAMPER (A67714)
2017 JAYCO WHITE...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
