Loader Bucket hooks
/ Bucket hooks #1
Engine Mike
Rochester hills michigan
Kubota B2320
I have a new 4WD Kubota B 23 HP 2320 with loader. Great machine. Does anyone have advice on installing hooks on the bucket to help lift heavy objects?
/ Bucket hooks #2
You could have chain hooks welded on or you could get some bolt on hooks. Mine are welded on. Kens Bolt ON Hooks is a good source of bolt on hooks and he sells the weld on hooks too.
/ Bucket hooks #3
mount them inline with your loader arms.
/ Bucket hooks #4
Get some Weld on hooks, put them in line with the loader arms, and reinforce the top lip of the bucket if needed with an L shaped bracket to keep if from being compressed or extended. On the Kubota bucket shown, I put a piece of steel that goes the entire length. but on the Kioti bucket it was already supported, and a pad was already provided to weld the hooks too.
James K0UA
/ Bucket hooks #7
Ok thanks guys. Some say to add 3. Two in line with the arms and 1 in the middle. Agree?
Thats good, or what some do is add a 2 inch receiver and then you can put a hook, a ring or the anchor for a boom pole, or any number of other things in the center. Anything you can think of that will fit a 2 inch receiver can be put on in a few seconds.
James K0UA
/ Bucket hooks #9
I agree with k0ua. Put a 2 inch receiver tube in the middle. I keep a GN hitch ball mount in mine. A boom pole can also go in that spot for hanging trusses. Or you can leave a hook in the tube. When am lifting a really heavy object, I just wrap the chain around the 2 inch receiver tube and ball mount.
This AFTER I welded a 3/8th inch thick angle iron across the whole span of the top lip.
hugs, Brandi
/ Bucket hooks #10
I say 2 hooks is perfect since you only have a 48" bucket I think, lift capacity is about 600-800lbs IIRC.
/ Bucket hooks #12
Here is what I did on my B3030. The hooks on the far corners were welded on when I bought the tractor. Messicks of PA installed them at this location.
213121 (A64276)
213121 (A64276)
UNUSED FUTURE CAT 303 38" EXCAVATOR RAKE (A65055)
UNUSED FUTURE CAT...
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
2017 FORD F550 4X2 S/A SERVICE BODY TRUCK (A67737)
2017 FORD F550 4X2...
2017 Freightliner M2 106 Passenger Bus (A66736)
2017 Freightliner...
2012 FOREST RIVER SALEM (A67714)
2012 FOREST RIVER...
