bucket extension
/ bucket extension #1
dieselcrawler
Elite Member
Lucasville Ohio
2013 JD 3005 2001 Kubota BX1800
Tired of makin so meny trips to the manure pile. Wife is getting tired of the muddy tracks to it also. So in an effort to cut down time tramming and the number of passes thru the mud... I thru together a bucket extension today. Can get 3x the horse manure in there now.
/ bucket extension #2
Did you have to add extra rear ballast for the extra weight in bucket?
Nice job.
/ bucket extension
Its horse manure mixed with hay... not gravel! No issues with rear ballast, even with just the box blade on the rear. Normally have the brush hog back there. I do have the tires loaded tho. Not that added rear ballast wouldn't help... I plan to make a rack on the BB to hold a few cement blocks for that very reason.
/ bucket extension #4
my bucket is bowed pretty bad ,it was like that when i got it ,need to pull it back up and weld in a piece in the center to hold it.
RICK
/ bucket extension #5
That's a load of s&%t!
Clean install and works well. What else can you ask for.
/ bucket extension #6
Since it's bolted in, I'm guessing you don't use the bucket for much else?
/ bucket extension
Right now, no, its not getting used for much else. Cleaning stalls is the only reason its come outta the barn for the past month. And in 5 min or less I could remove it, only has 4 small bolts holding it in. I plan to replace the fasteners
with wing nuts so no tools are needed but untill then... yup it works great. Simple effective and best of all free. Nice having everything you need to make an idea work right there on hand.
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
iDrive TDS-2010H...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
