bucket cylinder
/ bucket cylinder #1
pitbullinc
new holland tc40
Anyone know how the cylinder comes apart on a nw 16la loader. It looks like it would thread apart but I am wrenching on it so hard it is marring up the tube etc. It has two flats on the sides for a big wrench but its so tight it will strip it.
/ bucket cylinder #4
hi if you are going to rebuild it try putting heat to the tube.
brian
/ bucket cylinder #5
Refreshing a really old thread, specific to the NH 16LA bucket cylinders.
The bucket cylinders on my 2001 16LA use threaded end caps, 2-1/2" diameter heads with 2 small flats at 2-3/8" across. That doesn't provide much bite for traditional wrenches, they'll just round-off the corners. I had to cook-up a clamped-on arrangement, using a 4-foot 2" angle iron, and thick steel brackets from my engine stand.
Edit: Looks like the attachments loaded out-of-order.
Attachment 2 - Typical thick steel engine stand brackets.
Attachments 1, 3, 4 - The 4-foot angle iron, thick brackets, 1/2" grade 8 bolts/nuts.
Get everything lined-up on the end cap's flats, torque the bolts down 'till your elbows crack.
At about 80 lbs force on the end of the 4-foot angle iron, the end caps *snapped* loose.
That's about 300 ft-lbs of torque to loosen those things...
/ bucket cylinder #6
Simple but effective! Good job!
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2007 Dodge Ram...
Volvo 10ft Loader Rake Attachment (A64553)
Volvo 10ft Loader...
Oliver 1800 Tractor (A66285)
Oliver 1800...
1999 Trailmaster Aluminum 407 T/A Chemical Tanker Trailer (A64194)
1999 Trailmaster...
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
Ford 3430 Tractor (A65579)
Ford 3430 Tractor...
