bucket cylinder
/ bucket cylinder #1
pitbullinc
new holland tc40
Anyone know how the cylinder comes apart on a nw 16la loader. It looks like it would thread apart but I am wrenching on it so hard it is marring up the tube etc. It has two flats on the sides for a big wrench but its so tight it will strip it.
/ bucket cylinder #4
hi if you are going to rebuild it try putting heat to the tube.
brian
/ bucket cylinder #5
Refreshing a really old thread, specific to the NH 16LA bucket cylinders.
The bucket cylinders on my 2001 16LA use threaded end caps, 2-1/2" diameter heads with 2 small flats at 2-3/8" across. That doesn't provide much bite for traditional wrenches, they'll just round-off the corners. I had to cook-up a clamped-on arrangement, using a 4-foot 2" angle iron, and thick steel brackets from my engine stand.
Edit: Looks like the attachments loaded out-of-order.
Attachment 2 - Typical thick steel engine stand brackets.
Attachments 1, 3, 4 - The 4-foot angle iron, thick brackets, 1/2" grade 8 bolts/nuts.
Get everything lined-up on the end cap's flats, torque the bolts down 'till your elbows crack.
At about 80 lbs force on the end of the 4-foot angle iron, the end caps *snapped* loose.
That's about 300 ft-lbs of torque to loosen those things...
/ bucket cylinder #6
Simple but effective! Good job!
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2006 Sea Ray Sundancer 31ft Boat w/ Loadmaster 28ft Tri-Axle Boat Trailer (A64557)
2006 Sea Ray...
48 Inch Farm Jack (A65583)
48 Inch Farm Jack...
2001 Peterbilt 378 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2001 Peterbilt 378...
2011 18ft. Maxey Flatbed Utility Trailer (A64194)
2011 18ft. Maxey...
