buck tooth bucket
/ buck tooth bucket #1
txdon
Super Star Member
Central Texas
Kubota M6H-101
In welding class last year I made some buck teeth out of scrap. The Idea was to slip the teeth on the bucket's teeth, grab the mesquite and pull mesquite up by it's tap root without digging a very large hole.
/ buck tooth bucket
They install easy, just slip them on and a couple of taps with a hammer.....
/ buck tooth bucket
They look impressive installed!
/ buck tooth bucket #4
You got this mesquite slayer interested, how does it work? I hope well. mp
/ buck tooth bucket
Before I continue with the "demonstration" let's back up a bit and take a look at the problem.
With the regular teeth, the limber, long tap root mesquite, would simply slide through the teeth and refused to be pulled out. A large hole had to be dug to get the re-sprouting root out.
/ buck tooth bucket #6
I've seen similar to that bolted on the end of an FEL bucket to pull out trees as the guys are feeding cattle. These were on 100+HP tractors.........
ron
/ buck tooth bucket
Here is a picture of the very fist attempt as I revved up the motor whipped the bucket back and.......
.....the teeth did not move, the bucket did, but not the teeth. /forums/images/graemlins/shocked.gif
/ buck tooth bucket
OK, now that you have stopped laughing /forums/images/graemlins/blush.gif/forums/images/graemlins/grin.gif any ideas on connecting the teeth better or should the idea be scrapped. /forums/images/graemlins/smirk.gif
After getting on and off the tractor several times to put them back on I finally threw them aside and dug a deep hole.
"Buck Teeth II" will have shorter "V" teeth, that connect better.
/ buck tooth bucket
Here are a few more pics I shot while getting on and off the BH. I think it will work with the modifications.
/ buck tooth bucket
Last pic. I needed to get lower the tap root broke off.
/ buck tooth bucket #11
Looks like a "bugs bunny" backhoe bucket! /forums/images/graemlins/grin.gif
Seriously though,
</font><font color="blue" class="small">( any ideas on connecting the teeth better or should the idea be scrapped)</font>
If the fit on the sides was a little better, you could make dimples on the backhoe teeth and punch the side of the buckteeth into to them...like the way scarifier teeth are held on boxblade rippers. Knock 'em back off when done. I thought about set screws and dimples too, but not bolts sticking out that might get bent.
/ buck tooth bucket
<font color="blue"> ""bugs bunny" backhoe bucket" </font>
That would have been the perfect subject line! /forums/images/graemlins/grin.gif
The set screws threaded on the side sounds workable. Thanks.
/ buck tooth bucket #14
Hi, I would not scrap it, it looks great it just needs a little modifying. I would drill two holes in the bottom side right under where the teeth are, and then weld a nut right over the holes so you can put a lock bolt up through the bottom like a set screw and it should hold the teeth in place .When your done with the teeth just loosen the two bolts and take it off. I hope this will help you let us know what you decide to do .BULL
/ buck tooth bucket #15
TXDon, Is the steel thick enough to simply drill and tap it for a 1/2" bolt, or weld a nut onto to use the bolt? Since it is a specialty item that you may take on and off, I don't think a bolt, or 2, on the inside of the bucket would be a problem. Just keep the bolt as short as possible.
/ buck tooth bucket #16
Don,
What I would do is to weld a 2" wide strip of steel to the back of the rabbit teeth. Then drill one hole through it and the bucket.
/ buck tooth bucket #17
First there was the MMM and now there is the BBBB. /forums/images/graemlins/wink.gif
Looks like an interesting idea, I would keep working on it as anything that can rip out a mesquite with minimal effort on your part is worth a LOT.
/ buck tooth bucket #18
Don you don't need to get the whole tap root, ya just have to get that portion right below the surface that some call the nut.
It's easier to see on bigger Mesquites..most of the side roots are jutting from it.
Them BugsBunny teeth look like they will work as long as ya can keep em on the BH bucket and the set screw ideas sound good.
On them little 1 - 2" *&%$!*$@ I swear it takes a bigger hole than the 4 - 6 inchers to get them up...theres nothin to grab onto.
/ buck tooth bucket #19
I love the teeth, TXDON. Have you considered changing the design a bit to use them INSTEAD of your middle 2 teeth? Your Kubota bkt has bolt-on teeth and you could leave your V-teeth on all the time. I have considered repacing my bkt teeth with something like yours, but not to remove roots. I want sharp pointed teeth to better dig into my very hard soil and to break apart sandstone. A CASE 580 operator I hired years ago had pointed teeth on his bkt which did a great job.
/ buck tooth bucket #20
</font><font color="blue" class="small">( OK, now that you have stopped laughing /forums/images/graemlins/blush.gif/forums/images/graemlins/grin.gif any ideas on connecting the teeth better or should the idea be scrapped. /forums/images/graemlins/smirk.gif
)</font>
Okay, it took me several days to stop laughing, and as long as I don't open the attachment I won't start laughing again. /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif
Trouble with setscrews is it takes too long to get off and back on. For a quick on-off, how about magnets? Then you might be able to take it off by rubbing it backwards on the ground and pick it up by getting the teeth close and have it "jump" on your bucket like a set of lost bunny teeth....oh crud...I'm starting to laugh again. /forums/images/graemlins/laugh.gif
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61307)
2021 Takeuchi...
2019 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A60736)
2019 INTERNATIONAL...
M998 (A55852)
M998 (A55852)
Sdlanch SDLD25 (A60463)
Sdlanch SDLD25...
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
