Brush Hog Maintenance
   / Brush Hog Maintenance #1
Mitche11
International 4440
I have a FarmForce bush hog that was under water from a flood.
I have greased all fittings. Should I drain the gear box and refill with new gear oil?
Where is the gear box drain plug located? Must the disc that holds the 2 blades be removed to gain access to the drain plug? MD
   / Brush Hog Maintenance #2
I'm unfamiliar with that brand, but I would definately replace gear oil if unit has been submerged. On most shreders I've used the drain plug is on the side of the gear box, above the deck. Sometimes it is a drain plug like on a car with a hex "bolt" head, sometimes a pipe plug with a square head and sometimes a allen wrench type plug. Even if on the bottom, I would thnk there is enough room to get a wrench in between the stump jumper and the plug.
Good Luck
   / Brush Hog Maintenance #3
Definitely change the oil. I would grease the shaft as best you can as well
   / Brush Hog Maintenance #4
Some units do not have a drain plug. You can buy a $11.00 suction gun at your local Autozone.
And yes, drain that gear oil
   / Brush Hog Maintenance #5
drain and fill are likely the same. if it swam.. I'd probably flush the box with diesel and swing it upside down and train and perhaps use a garden pump sprayer loader with diesel to irigate it.. drip dry, then refill with gear oil.
when you grease.. grese all fittings till old grease is pushed out.. except don't overgreas ethe tail wheel hub if it is a seled kind.. can push the seals out..
soundguy
   / Brush Hog Maintenance #6
Mitche11...(hopefully) attached is a copy of the page from my manual. I also have a Farm Force cutter.
  • Farm Force and King Kutter.pdf
2015 Acura ILX Sedan (A59231)
2015 Acura ILX...
2025 Nationcraft 8.5X36TTA3 38ft Tri-Axle Enclosed Trailer (A59231)
2025 Nationcraft...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
2017 Nissan Rogue SUV (A59231)
2017 Nissan Rogue...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
