Rotary Cutter Brush Hog Blades COMING OFF
   / Brush Hog Blades COMING OFF #1
Asar2525
Pownal, VT
Farmall 140/Super C/International 300
I seem to be having the opposite problem of most people. I have an old brush hog (FMC Sidewinder) that I've used for the past 4 years. I use it for pasture mowing and cutting down weedy parts of hay fields, but also for mowing brush that grows up in our woodlot.
So far this year I have had a blade come off 4 times. I've had good luck finding the blade but keep losing bolts... I just tried putting Nord-Lock washers on both blades but had a blade come off even with those! Every time I tighten the nuts I use a 3/4" drive T-bar with a 3ft pipe and torque it down as hard as I can. I'm nearly at wits end and am seriously considering welding the nut on the bolt. Any suggestions would be greatly appreciated.
   / Brush Hog Blades COMING OFF #2
Are you sure your using the correct bolts for your cutter, most of the side winders I’ve had use the bolts with a flat side.
I'm using the type with a raised portion that keeps the bolt from spinning. It looks like someone redid the bolt holders at some point before I owned it.
ATRC11 Blade Bolt Kit at Tractor Supply Co.
I would think this would work fine since it keeps the bolt from spinning.
   / Brush Hog Blades COMING OFF #4
Redid the holders as in how?
From what I can tell the holes in the original stump jumper got stretched out so there is a 3/8" plate welded on the bottom and a 3/8" plate welded on the top of the stump jumper that holds the bolt. These each have a 1 1/8" hole drilled in them and the bottom one has a small part machined out for the crimped "tab" on the bolt that keeps it from rotating. It's very heavy duty.
   / Brush Hog Blades COMING OFF #6
You probably need a cotter pin through the bolt after you put the nut on. Do you have a hole in the bolt at the end? If so, use a castle but and a cotter pin
atcNick, There is no hole for a cotter pin and it isn't a castle nut.
   / Brush Hog Blades COMING OFF #8
Here’s kinda what it should look like
   / Brush Hog Blades COMING OFF #9
Hmm... man. I would think that’s standard. I wonder how easy it would be to replace the shaft bolt. I had the same problem as you. It was constantly falling off... once I realized what the cotter pin hole was for I haven’t had an issue since
   / Brush Hog Blades COMING OFF #10
I would get another brush hog, before something, or SOMEONE, gets hurt. I would NOT take the risk of keep using it. You have been lucky four times. Two would have been my limit.
Rhino FM72 Finishing Mower (A51573)
Rhino FM72...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2016 Ram ProMaster 1500 Van, VIN # 3C6TRVAG2GE105143 (A51572)
2016 Ram ProMaster...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
