Rotary Cutter Brush Hog Blades COMING OFF
   / Brush Hog Blades COMING OFF #1
Asar2525
Pownal, VT
Farmall 140/Super C/International 300
I seem to be having the opposite problem of most people. I have an old brush hog (FMC Sidewinder) that I've used for the past 4 years. I use it for pasture mowing and cutting down weedy parts of hay fields, but also for mowing brush that grows up in our woodlot.
So far this year I have had a blade come off 4 times. I've had good luck finding the blade but keep losing bolts... I just tried putting Nord-Lock washers on both blades but had a blade come off even with those! Every time I tighten the nuts I use a 3/4" drive T-bar with a 3ft pipe and torque it down as hard as I can. I'm nearly at wits end and am seriously considering welding the nut on the bolt. Any suggestions would be greatly appreciated.
   / Brush Hog Blades COMING OFF #2
Are you sure your using the correct bolts for your cutter, most of the side winders I’ve had use the bolts with a flat side.
I'm using the type with a raised portion that keeps the bolt from spinning. It looks like someone redid the bolt holders at some point before I owned it.
ATRC11 Blade Bolt Kit at Tractor Supply Co.
I would think this would work fine since it keeps the bolt from spinning.
   / Brush Hog Blades COMING OFF #4
Redid the holders as in how?
From what I can tell the holes in the original stump jumper got stretched out so there is a 3/8" plate welded on the bottom and a 3/8" plate welded on the top of the stump jumper that holds the bolt. These each have a 1 1/8" hole drilled in them and the bottom one has a small part machined out for the crimped "tab" on the bolt that keeps it from rotating. It's very heavy duty.
   / Brush Hog Blades COMING OFF #6
You probably need a cotter pin through the bolt after you put the nut on. Do you have a hole in the bolt at the end? If so, use a castle but and a cotter pin
atcNick, There is no hole for a cotter pin and it isn't a castle nut.
   / Brush Hog Blades COMING OFF #8
Here’s kinda what it should look like
   / Brush Hog Blades COMING OFF #9
Hmm... man. I would think that’s standard. I wonder how easy it would be to replace the shaft bolt. I had the same problem as you. It was constantly falling off... once I realized what the cotter pin hole was for I haven’t had an issue since
   / Brush Hog Blades COMING OFF #10
I would get another brush hog, before something, or SOMEONE, gets hurt. I would NOT take the risk of keep using it. You have been lucky four times. Two would have been my limit.
Ambulance (A52377)
Ambulance (A52377)
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2015 FORD E350 16FT BOX TRUCK (A52576)
2015 FORD E350...
2023 John Deere HD50F Draper Head (A53342)
2023 John Deere...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
