Brush Fork DIY Build
/ Brush Fork DIY Build #1
SJay
Tri City Area, MI
Bobcat CT225 Tractor, John Deere 4x2 Gator, Husqvarna Zero Turn, John Deere Buck 650 ATV
First I would like to thank everyone who contributes on the TBN. I have learned many things since joining TBN just a few months ago. Second, I wanted to build a set of brush forks for my Bobcat CT225 tractor. Putting a few ideas together that I have seen on TBN I came up with the following design. I still have some things to finish up - ran out of time this week end.
Material - 2"x2" 3/16" Tubing, 1"x2" 3/16" Tubing.
Dimension: 60" width and the length of each fork is 35"
Any Questions or comments - fire away :thumbsup:
/ Brush Fork DIY Build #2
Interesting project!!! What's the plan for fastening them to the bucket??
I am going to use 2"x2" 3/16" angle welded to the top of the left and right fork and then bolted to the side of the bucket. I am also planning on putting 2 legs under the bucket to kinda sandwich the forks to it.
/ Brush Fork DIY Build #4
Problem is going to be the amount of leverage the forks can exert on the bolts. Better use Grade 8 and keep them very tight. The legs under the bucket will help some.
When using these you will have to be very cautious about over loading one fork. I think your tractor will have the ability to bend one if it's doing all the work alone.
/ Brush Fork DIY Build #5
Good choice for metal! Agree with ovrszd about the potential to bend. Just need to be aware when using it.
/ Brush Fork DIY Build #6
Did you consider hooking the front of the bucket lip running it under the bucket and chain or strapping to the top of the bucket from behind.
Yes, I will definitely be using grade 8 bolts. I do realize that if I am not cautions - things can get bent, broke, smashed and damaged. :D. No, I did not consider using a strap to hold the forks on.
/ Brush Fork DIY Build #8
Just curious why you are using tubing for the tines. I built a set of forks that I use around 90% of the time. I used 1 1/4" ???? Sinker rod. It really holds up nice.
I had seen a few design using the square tubing (which I am sorta copying :) - not so many with the round bars. No real scientific reason.
/ Brush Fork DIY Build #10
built these some time ago, easy on/off, no issues w' bucket damage, easy to build. your mileage may vary.
http://www.tractorbynet.com/forums/build-yourself/193825-easy-forks.html?highlight=easy+forks=
I used hss on mine because of the weight limitations of the loader on my scut. every pound the forks don't weigh, I can pile on something else. :)
/ Brush Fork DIY Build #11
/ Brush Fork DIY Build #13
I'm looking to build a at as well. I'm planing to use 1 1/4 inch tube 3/8 thick. I'm also going to make it a bucket on to its self. 4 tines spaces out to work as forks. It's for my bobcat ct 120. It can only pick up 700 lbs at the most and probably 400 lbs at the tip of the tines
/ Brush Fork DIY Build #14
Thickest wall I see in that size tube is 3/16".
/ Brush Fork DIY Build #15
Hi Sjay,
You may have seen my brush forks. Thread HERE.
I had a set that was bolted in, and it became a PITA. I used 1/2" bolts, and they NEVER moved. Never gave a hint that bolting (8" apart) was anything but PLENTY strong for brush forks.
Then I changed the attachment, so it slid into angle-iron 'slots'. The forks were 1/4" narrower than the bucket. I would NOT make it any tighter - 1/4" was enough trouble. The slot was much better, I could remove the forks quickly and scoop the dregs of a pile, then just slide the forks back in. I actually never did 'retain it' in the slots, and it never had any trouble. One day, thinking I'd better retain it before something happens, I instead scrapped the slots idea entirely and went to a Quick-Release system. I am very happy with it.
389650d1410215599-50-inch-brush-fork-build-brushforkb2710lock_unlock-jpg
My forks are 1x2x1/8" x 50" tines. And theres FIVE tines. My tractor lifts about 900lbs in the bucket. Maybe you can apply this to your tractor's capacity. I had to add 1/8" doublers on my forks, top and bottom, and now they are much stronger and I think the right strength for my tractor. Here's what the 1x2x.120 tines look like with the doublers. I only added thickness where it was necessary. I'm glad it's no heavier than it is (but yours looks a bit stronger!).
421386d1429334309-question-about-duty-cycle-167-inches-welding-jpg
Thanks for the info Sodo. Still in the fabrication stages. I think the 3/16" wall thickness will help the structural strength of the tines. I do like the way you attached the forks to your bucket. I am going to try and use them bolted on - if it ends up being a pain, I may change it later. When I get more of the forks done I will post more pictures.
/ Brush Fork DIY Build #17
I've been thinking again. :(
How about some brush forks that will slip/wedge over the bucket edge and bolt to the bucket in the rear, but will also slip over the points of the tooth bar when it is on. Probably with the rear of the forks under the bucket instead of inside. Long, horizontal tabs, with 2 holes each, outside the bucket for fastening. Or a strap to the rear of the bucket.
Another idea drifting around my head:
A 2 or 2.5 inch square bar that goes side to side, under and slightly behind the bucket edge and also fastens to the rear of the bucket. The bar has 4-6 six inch hitch receivers welded to the front of it. It would look sort of like a hitch receiver with a bunch of receivers instead of just one. Use 2 inch square tube forks. Fill all the receivers for brush forks. Fill just two for pallet forks. Maybe two different spacings for the pallet forks. Use very short "forks" for a tooth bar.
Bruce
/ Brush Fork DIY Build #18
/ Brush Fork DIY Build #19
Just a thought for those of you in the planning stages; I have five tines and that's fine for my logs I handle but with the brush I always wish I had more. I plan on building another set with more tines and a grapple one day.
/ Brush Fork DIY Build #20
I shamelessly copied rjmack's design, using scrap hollow tubing, with chains to anchor to the back of the bucket, and they work like a charm. Thanks rjmack!
