brush cutter dimensions
/ brush cutter dimensions #1
Oldstuff
Missouri
'63 Ford 2000
I'm in the process of upgrading to a tractor that has a FEL (not quick disconnect) but am trying to determine if it will fit in my shed with a bruch cutter on it. I know the exact distance from the front of the FEL to the holes in the lift arms at the rear and it looks like my brush cutter (King Kutter) is 8 inches toooo long. I have looked at a couple of websites to determine the physical size is in length and some do not list the length.
Does anyone know of one brand being shoerter than others?
Thanks- Oldstoff
/ brush cutter dimensions #3
Did you addon deck wheel?
/ brush cutter dimensions #5
King Kutter? What size? I can measure my 5 foot one when the rain stops.
wirlbird, it is a 5 footer- I cannot check myself because tractor is 160 miles away
Thanks
/ brush cutter dimensions #7
Just went out and measured my 5 ft wallace , Right at 8 ft from tailwheel to pins,
/ brush cutter dimensions #8
Thanks
Mine was a little tricky to get to due to where I have it stored but looks like 78-80 inches. Definitely under 7 feet.
Thanks wirlybird
2017 JAYCO WHITE HAWK CAMPER (A67714)
2017 JAYCO WHITE...
2025 32in Tilt Bucket Mini Excavator Attachment (A66734)
2025 32in Tilt...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
CAT D5N Winch (A68134)
Unused HLA HD42 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused HLA HD42...
2007 JLG 450AJ TELESCOPIC BOOM LIFT (A65056)
2007 JLG 450AJ...
