Brush clearing down steep hill, need advice!
/ Brush clearing down steep hill, need advice! #41
That is the same thing I picked up, Outback by Billy Goat, it does a number on blackberries but is a lot of work on a slope, I think they have pressure lubed engines so not quite as bad as slingers, I don't have long slopes so not a big deal for me.
/ Brush clearing down steep hill, need advice! #42
skidder with a forestry head for initial clearing, then maintain it by hand
Last quote I got was $800/day for the head only, $1200/day for the whole machine with operator. You offering to pay?
I have a brush mower and I would not recommend it on a steep slope.
/ Brush clearing down steep hill, need advice! #43
<snip> Any experience with the walk behind brush cutters?
I have a Goldoni (Italian, similar to (but not interchangeable with) BCS) 2 wheel tractor with a sicklebar and a rotary lawn mower.
The sicklebar is awesome when wading into dense briars. On one occasion when I did so the bar just passed under 16" spherical boulders. A sickle bar makes only one cut and uses little energy (old haying machines were horse-drawn, ground driven) so it will cut (most) anything that fits between the teeth and chew down 2" saplings. It will not cut a steel fence post and will break teeth on heavy gauge wire. The problem with one-cut is that you still have to deal with the slash.
The lawn mower has a 2' long, 3/8" thick, rotary blade. Putting 10 hp into a 2' swath, it will chew up anything it can push down. When I entered "unknown" brush I found a stump that broke the shear-bolt-like clutch on the mower shaft. Goldoni also marketed a "brush cutter" that had a 2' diameter, semi-shrouded, horizontal, toothed blade not unlike what I remember in old Gravely brochures.
The problem with front attachments on Italian 2-wheel tractors is that, when the front attachment is mounted, the engine is low, and the ground clearance is very limited. Uneven ground or even the hole left by a displaced cobble may hang the machine up. My machine has a reverse gear and separate dog clutches for each wheel. I have never had to winch it unstuck, but I have had wrestling matches with it.
Captain Dirty
PS. I have used a bicycle-handlebar type of brush cutter with a saw blade, and with my rocky land, promptly "cupped" the blade by bending all the downward set teeth upwards.
/ Brush clearing down steep hill, need advice! #44
A technician that shows up with a suitcase of light tools charges $100.00 an hour! And you don't think showing up with a man as well as $50-175K of insured equipment (Depending on truck and trailer) is worth $1200 a day? Mind you, the proper equipment would make short work of that job. Maybe not even worth doing.
/ Brush clearing down steep hill, need advice! #46
/ Brush clearing down steep hill, need advice! #47
Himalayan blackberries on one of my places can grow 2 stotries tall with stems 20 feet. Adding a slope would make a walk behind impossible, the berry canes would snag you. Other properties they just grow about 5 or 6 feet tall. So it all depends.
One guy I knew (not on a slope) cleared a 2 acre patch with a dozer and dozed about 1 foot of topsoil into a ravine to encapsulate the rootballs. Then he only had the top of the ravine to treat with crossbow.
A picture of your slope would help.
/ Brush clearing down steep hill, need advice! #48
Goats!
Tires? R1 ag or R4 construction?
Chains can improve traction especially with R4 tires. Sometimes I have to put crampons (chain/spikes) on my boots stick on steep terrain using chainsaw or clearing saw.
Cleared and maintained several steep acres with Kubota M5030. R1 ag tires. Newer Kubota M59 with R4 tires no-go
