Brush clearing down steep hill, need advice!
   / Brush clearing down steep hill, need advice! #41
That is the same thing I picked up, Outback by Billy Goat, it does a number on blackberries but is a lot of work on a slope, I think they have pressure lubed engines so not quite as bad as slingers, I don't have long slopes so not a big deal for me.
   / Brush clearing down steep hill, need advice! #42
skidder with a forestry head for initial clearing, then maintain it by hand
Last quote I got was $800/day for the head only, $1200/day for the whole machine with operator. You offering to pay?
I have a brush mower and I would not recommend it on a steep slope.
   / Brush clearing down steep hill, need advice! #43
<snip> Any experience with the walk behind brush cutters?
I have a Goldoni (Italian, similar to (but not interchangeable with) BCS) 2 wheel tractor with a sicklebar and a rotary lawn mower.
The sicklebar is awesome when wading into dense briars. On one occasion when I did so the bar just passed under 16" spherical boulders. A sickle bar makes only one cut and uses little energy (old haying machines were horse-drawn, ground driven) so it will cut (most) anything that fits between the teeth and chew down 2" saplings. It will not cut a steel fence post and will break teeth on heavy gauge wire. The problem with one-cut is that you still have to deal with the slash.
The lawn mower has a 2' long, 3/8" thick, rotary blade. Putting 10 hp into a 2' swath, it will chew up anything it can push down. When I entered "unknown" brush I found a stump that broke the shear-bolt-like clutch on the mower shaft. Goldoni also marketed a "brush cutter" that had a 2' diameter, semi-shrouded, horizontal, toothed blade not unlike what I remember in old Gravely brochures.
The problem with front attachments on Italian 2-wheel tractors is that, when the front attachment is mounted, the engine is low, and the ground clearance is very limited. Uneven ground or even the hole left by a displaced cobble may hang the machine up. My machine has a reverse gear and separate dog clutches for each wheel. I have never had to winch it unstuck, but I have had wrestling matches with it.
Captain Dirty
PS. I have used a bicycle-handlebar type of brush cutter with a saw blade, and with my rocky land, promptly "cupped" the blade by bending all the downward set teeth upwards.
   / Brush clearing down steep hill, need advice! #44
A technician that shows up with a suitcase of light tools charges $100.00 an hour! And you don't think showing up with a man as well as $50-175K of insured equipment (Depending on truck and trailer) is worth $1200 a day? Mind you, the proper equipment would make short work of that job. Maybe not even worth doing.
   / Brush clearing down steep hill, need advice! #46
   / Brush clearing down steep hill, need advice! #47
Himalayan blackberries on one of my places can grow 2 stotries tall with stems 20 feet. Adding a slope would make a walk behind impossible, the berry canes would snag you. Other properties they just grow about 5 or 6 feet tall. So it all depends.
One guy I knew (not on a slope) cleared a 2 acre patch with a dozer and dozed about 1 foot of topsoil into a ravine to encapsulate the rootballs. Then he only had the top of the ravine to treat with crossbow.
A picture of your slope would help.
   / Brush clearing down steep hill, need advice! #48
Goats!
Tires? R1 ag or R4 construction?
Chains can improve traction especially with R4 tires. Sometimes I have to put crampons (chain/spikes) on my boots stick on steep terrain using chainsaw or clearing saw.
Cleared and maintained several steep acres with Kubota M5030. R1 ag tires. Newer Kubota M59 with R4 tires no-go
2017 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2017 DRAGON 150...
Truck Metal Cargo Storage Box (A55787)
Truck Metal Cargo...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55302)
PENDING SELLER...
1995 Western Star 4900 T/A Wrecker Tow Truck (A55788)
1995 Western Star...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
