ericm979
Super Member
- Joined
- Nov 25, 2016
- Messages
- 5,835
- Location
- Santa Cruz Mountains CA, Southern OR
- Tractor
- Branson 3725H Deere 5105
Check with the county and the fire service that covers your area to see if it's ok to burn now. It's not just California, it's dry in much of Oregon now too.
If it's too steep for equipment the brush cutter is a good answer. If you're going to be using it a lot it pays to buy a good one. The one problem with brush cutters is when the brush is thick and you need to move or pile cut brush in order to keep working. You have to take the cutter off the harness in order to pull or pile brush, then start it and put it back on. That will slow you down a lot. Much of my brush is that thick, so I use a small chain saw. A good battery powered saw might be the best for this.
I have a Stihl FS240 which I use with a saw blade as a brush cutter and with a string trimmer head as a powerful string trimmer. The walk behind trimmers (DR etc) usually have four stroke engines that can't handle operating on steep slopes. Many people in my area have tried them and burnt up the motors due to slope caused oiling problems.
You'll want to remove the cut material and chip it or pile it and burn it in the winter if you have a safe place to do so and it's legal. The roots will still be alive and will send up shoots in the spring. That's the time to hit them with Garlon4. Otherwise the plants will grow back quickly.
