Bruised Kubota
/ Bruised Kubota #1
Sailorcrew
Londonderry, NH
Kubota L3010, loaded r'4s and an Ingersoll 4018
Well, I now have a scrape on my tractor. The first of many, I'm sure. I told my wife I have two choices, trade it or try to touch it up. Needless to say, the debate lasted about 2 seconds. So, what methods do you all use to touch up? This one is just a small abrasion, the tiltmeter was taped to the loader crossbar and over the last several hours, vibrated against the hood of the tractor. Very minor paint removal, but down to the primer. Not whining, just wondering what methods are used to repaint, from simple wear to deep gouges, like on the loader bucket. Once winter comes and my time on the tractor decreases I'll do all those things I want to do, touch ups, storage boxes, bucket chain hooks, etc. David
/ Bruised Kubota #2
David, several people, in the past, have mentioned some other brands of paint that match, but I just bought genuine Kubota aerosol paint from the dealer; one can of orange and one of gray (and haven't used either one yet).
Bird
/ Bruised Kubota #3
Bird, let me know how the orange matches, most of the time it's not even close!?
/ Bruised Kubota #4
I have not found the "paint in a can to match well and since it is a single part will not offer the durability of two part paints. For a touch up fine but your hood--?--I would remove it--strip to steel--shoot it with an epoxy primer and then follow with custom matched paint availble at any paint supply. You could have a body shop do it. OR--you could just prime the gouge--spray on some orange paint and live with it till it tries to rust and then deal with it--if ever. J
/ Bruised Kubota #5
That would be about my normal luck./w3tcompact/icons/frown.gif Of course, they had two different orange colors and I, supposedly, got the right one. And I bought them several months ago; just haven't used them yet, like I planned to.
Bird
/ Bruised Kubota #6
I've bruised my B2100 and found that Ace Hardware carries a "Machine and Implement" rust stopper enamel that exactly matches the factory paint. The last time I posted this, Bird replied his Ace guy never heard of it. The info on the upc code is 17132 Allis Chalmers Orange and the upc code nos are 8290117132. I'm sure it's cheaper than factory paint since the 15 oz spray can was less than $5.00
By the way, Muhammed, this is the best of all sites I've ever encountered on the net.
/ Bruised Kubota #7
Feather the edges of the "gouge" starting with 320 and finishing with 400 grit sandpaper. It's in my opnion optional to use primer on a tractor but spray with primer. Sand and feather again. Primer is used to build up the area to the original height. You will notice that Kubota uses several layers of paint as you feather the edges. Finish sand the area with 400 or 600 grit. Spray the area with Kubota brite orange II. Do your best to blend the edges of the repair with the existing original finish. Do 3 or 4 lite coats allowing a couple of minutes between coats. This allows a build up of thickness without the paint running. After the paint is completely cured (about 2 weeks) gently rub down the area with an auto polish (use the kind that has no wax in it). This will help in blending with the original finish. Short of taking it to an auto body shop this will produce a good result and is overkill for a tractor. This will take you quite a while and after you are done you will think twice about it the next time around. Get a book or video on auto painting or visit the local auto body shop for a couple of hours.
Don't worry about the "bruises". They happen. The only repairs I do are to make sure to keep the rust away. The cosmetics are a bonus.
I used to paint cars many years ago. I still have some of the equipment. Usually what I do is just sand with 320 and paint with the finish color. It's only a tractor.
/ Bruised Kubota #8
<font color=blue>let me know how the orange matches, most of the time it's not even close</font color=blue>
Really??? The dealer gave me a full spray can with my tractor "in case I scratched it anywhere"....didn't take long! I touched it up and I can barely notice where the touch up is. I think it was a good match.
Kevin
/ Bruised Kubota #9
After reinforcing the upper edge of the bucket on me B 2710 I sprayed it with a can of the Kubota touch up paint. It not only stuck to the new metal but the color was a very good match.
/ Bruised Kubota #10
I have a real hard time keeping paint on the front edge of my loader bucket. The darnn rocks keep scratching it off. Deep scratches take a long time to remove from the steel with 320 paper.
I have the same problems with my mower blades. Every nigh, after I wash them, I use quick dry spray paint before the wax.
/ Bruised Kubota #11
<font color=blue>I have the same problems with my mower blades. Every nigh, after I wash them, I use quick dry spray paint before the wax.</font color=blue>
Your Joking right? You paint and wax your mower blades.
I only wish I had enough spare time to consider that and if I did I am sure my mower blades, I have two sets for the BX, would forgive me for not indulging them.
Winnipeg, Manitoba
2001 BX2200 (30 hrs)
/ Bruised Kubota #12
The paint that Elmerinva recomended is right on the money I got the same thing for the grapple bucket I built and it is a perfect match.
/ Bruised Kubota
Pokey, now that you mentioned it, I have another question. When the little rubber "hairs" wear off a new tire, is it time to replace the tires? David
/ Bruised Kubota #14
Of course I'm joking. I'd get run off the ranch if I worried about a paint scratch.
I do paint my tractor projects, however. The local Tractor Supply Co. is having a clearance on Rustolium Tractor and Implement paint. Quarts were about $4.50. Allice Chalmers (sp?) orange matches very well. Shermin Williams wanted $120 per gallon for two part "safety orange" industrial paint. I',m very happy with the Rustolium and will get another quart if they (TSC) has it.
Wall mart sells Rustolum quarts in white and black. I mixed them to get the right Kubots gray color for my project canopy frame. The neighbor thought it was a factory canopy.
Tires get replaced when they can't be repaired again or when they no longer give traction.
Pokey
/ Bruised Kubota #15
i dont know how big the scrape is but an old used car dealer trick would be go to the kubota dealer and get a decal that would cover it . you would be suprized at how many new tractors with scrapes go out with a dealer name or a safety sticker on them...one who knows...
/ Bruised Kubota #16
I like the sticker idea myself/w3tcompact/icons/smile.gif
______________________________
Take care all, Jim
Semper Fidelis
/ Bruised Kubota #17
This sounds like my claim of a few months ago. Kubota Orange really looks like a cross of AC Persian Orange and Farmall Red.
RobertN in Shingle Springs Calif
/ Bruised Kubota #18
Out here, when the main Rubicon Jamboree is run on the famous Jeep trail, you can get large, like 12"x4" "bandaids to put on owee's like that /w3tcompact/icons/smile.gif They tend to bounce sheet metal on the rocks on trails like that.
I've been bugging our fantastic web master here for TBN coffe cups and the likes, like ytmag.com has. Maybe, if he ever does something like that, he could offer large bandaids, colored for our various brands of tractors /w3tcompact/icons/smile.gif
/ Bruised Kubota #19
I think that you will find that "Implement Enamel" is an alkyld (sp?) enamel. This stuff will look OK for a while but will fade quickly if left outside in direct sunlight. A better choice, but more expensive, is an acrylic enamel. This is the stuff many manufacturers used to paint cars before the two part urethane paints became popular. Acrylic enamel will hold its color and shine much better that an alkyld enamel. Also, Kubota orange looks exactly like the color Case used on its tractors back in the ‘40s and ‘50s. They called it “Flambeau Red”.
5 out of 4 school students have trouble with statistics. /w3tcompact/icons/smile.gif
Year: 2012 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 199,652 Plate: Body (A61573)
Year: 2012 Make...
2020 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A61573)
2020 Autocar...
2014 JAYCO JAYFEATHER TRAVEL TRAILER (A63569)
2014 JAYCO...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
2017 Toyota Tundra 4x4 Crew Cab Pickup Truck (A61573)
2017 Toyota Tundra...
EZ Trail 510 Grain Cart (A64047)
EZ Trail 510 Grain...
