Broken Log Splitter Pump
/ Broken Log Splitter Pump #1
Larry Wall
Harrington, De.
Case
Hi,
I'm new to this forum, but I am interested in many of the topics on this forum. I have a log splitter with a 10 Hp motor. It is a homemade splitter and the pump went up on it. I can't read any info on the pump and I need to replace it. What size pump should I get, and should it be a 2 stage or what?
Thanks
Larry
/ Broken Log Splitter Pump #2
Welcome to the forum. :welcome:
I'm going to move your thread to where it is more likely to be seen. Best of luck!
/ Broken Log Splitter Pump #3
16gpm, 2 stage pump will go nicely with 10hp motor.
Andy,
Thanks for the help. I was having a problem trying to figure this out. The old pump had no marking on it.
/ Broken Log Splitter Pump #6
Just remember you have to get a 'bell housing' that the pump mounts on one end, and fits your engine on the other. Don't buy a pump unless you can get that piece as well.
My pump came from Northern Hydraulics.
/ Broken Log Splitter Pump #8
How did you determine the pump was bad? The reason I ask is because the pump is the least likely thing to go bad on a splitter. A damaged pressure relief in the control valve, a slipping coupling between engine and pump , low fluid level , or bad seals in the cylinder are the usual culprits for splitter failures.
/ Broken Log Splitter Pump #10
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
Deere 700K (A64126)
Deere 700K (A64126)
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
2022 EZ-GO ELITE...
SUPER C PNEUMATIC GUILLOTINE SAW (A64281)
SUPER C PNEUMATIC...
