Broken Log Splitter Pump
/ Broken Log Splitter Pump #1
Larry Wall
Harrington, De.
Case
Hi,
I'm new to this forum, but I am interested in many of the topics on this forum. I have a log splitter with a 10 Hp motor. It is a homemade splitter and the pump went up on it. I can't read any info on the pump and I need to replace it. What size pump should I get, and should it be a 2 stage or what?
Thanks
Larry
/ Broken Log Splitter Pump #2
Welcome to the forum. :welcome:
I'm going to move your thread to where it is more likely to be seen. Best of luck!
/ Broken Log Splitter Pump #3
16gpm, 2 stage pump will go nicely with 10hp motor.
Andy,
Thanks for the help. I was having a problem trying to figure this out. The old pump had no marking on it.
/ Broken Log Splitter Pump #6
Just remember you have to get a 'bell housing' that the pump mounts on one end, and fits your engine on the other. Don't buy a pump unless you can get that piece as well.
My pump came from Northern Hydraulics.
/ Broken Log Splitter Pump #8
How did you determine the pump was bad? The reason I ask is because the pump is the least likely thing to go bad on a splitter. A damaged pressure relief in the control valve, a slipping coupling between engine and pump , low fluid level , or bad seals in the cylinder are the usual culprits for splitter failures.
/ Broken Log Splitter Pump #10
2015Ford Escape SUV (A61574)
2015Ford Escape...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
UNUSED WOLVERINE MAD-12-12D (A64281)
UNUSED WOLVERINE...
2019 F-550 Bucket Truck (A63689)
2019 F-550 Bucket...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
