Broken Log Splitter Pump
/ Broken Log Splitter Pump #1
Larry Wall
Harrington, De.
Case
Hi,
I'm new to this forum, but I am interested in many of the topics on this forum. I have a log splitter with a 10 Hp motor. It is a homemade splitter and the pump went up on it. I can't read any info on the pump and I need to replace it. What size pump should I get, and should it be a 2 stage or what?
Thanks
Larry
/ Broken Log Splitter Pump #2
Welcome to the forum. :welcome:
I'm going to move your thread to where it is more likely to be seen. Best of luck!
/ Broken Log Splitter Pump #3
16gpm, 2 stage pump will go nicely with 10hp motor.
Andy,
Thanks for the help. I was having a problem trying to figure this out. The old pump had no marking on it.
/ Broken Log Splitter Pump #6
Just remember you have to get a 'bell housing' that the pump mounts on one end, and fits your engine on the other. Don't buy a pump unless you can get that piece as well.
My pump came from Northern Hydraulics.
/ Broken Log Splitter Pump #8
How did you determine the pump was bad? The reason I ask is because the pump is the least likely thing to go bad on a splitter. A damaged pressure relief in the control valve, a slipping coupling between engine and pump , low fluid level , or bad seals in the cylinder are the usual culprits for splitter failures.
/ Broken Log Splitter Pump #10
Headache Rack (A61166)
2006 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2006 JLG 600S...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
New/Unused Landhonor 11ft x 19ft Carport with Open Side Walls (A61166)
New/Unused...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A62131)
UNUSED WOLVERINE...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1CJ453408 (A61165)
2012 International...
