Broken Log Splitter Pump
   / Broken Log Splitter Pump #1
Larry Wall
Harrington, De.
Case
Hi,
I'm new to this forum, but I am interested in many of the topics on this forum. I have a log splitter with a 10 Hp motor. It is a homemade splitter and the pump went up on it. I can't read any info on the pump and I need to replace it. What size pump should I get, and should it be a 2 stage or what?
Larry
   / Broken Log Splitter Pump #2
Welcome to the forum. :welcome:
I'm going to move your thread to where it is more likely to be seen. Best of luck!
   / Broken Log Splitter Pump #3
16gpm, 2 stage pump will go nicely with 10hp motor.
Andy,
Thanks for the help. I was having a problem trying to figure this out. The old pump had no marking on it.
   / Broken Log Splitter Pump #6
Just remember you have to get a 'bell housing' that the pump mounts on one end, and fits your engine on the other. Don't buy a pump unless you can get that piece as well.
My pump came from Northern Hydraulics.
   / Broken Log Splitter Pump #8
How did you determine the pump was bad? The reason I ask is because the pump is the least likely thing to go bad on a splitter. A damaged pressure relief in the control valve, a slipping coupling between engine and pump , low fluid level , or bad seals in the cylinder are the usual culprits for splitter failures.
There is a lot of play at the shaft of the pump.
   / Broken Log Splitter Pump #10
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
10' WROUGHT IRON SITE FENCE (A51248)
10' WROUGHT IRON...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2014 Ford Escape (A50323)
2014 Ford Escape...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
