Broken Drain Pipe
/ Broken Drain Pipe #1
Kevin_in_VA
Chesterfield, Va
NH TC30 Hydro
The shower drain in my basement bathroom has always leaked, and at times I have had minor sewage backups as well, so I decided to demolish the shower to determine the cause of the leak, repair it, and replace the shower with a tub/shower enclosure. Well today I finally got the floor of the shower out (tile over a lead shower pan), and discovered the worst case scenario, that the cast iron drain pipe was broken off below the surface of the concrete slab. I have now determined to decommission this in drain, and plumb the new bathtub to the kitchen drain pipe that is about a 18" away.
I've included a couple pictures.
My question is,
"How do I permanently plug this drain, without affecting other nearby pipes (the aforementioned kitchen drain) that drain into the same waste line?"
I'd appreciate any insight anyone could offer.
Best regards,
Kevin
/ Broken Drain Pipe #2
/ Broken Drain Pipe #3
/ Broken Drain Pipe #4
I don't know what happened because all I typed was www dot plbg dot com. This forum must have some sort of dynamic linking function that calls up the page.
/ Broken Drain Pipe #5
Before you start running new lines, this one may still be fixable. Get a masonary bit for a skill saw for about $40 and cut out a square around the drain line. Remove the concrete until you can get to the main line. Attach a new drain line to the old line and bring it up through the height of the floor by about six inches.
Pour concrete back into the hole and let set.
Put in new shower.
Cut off excess pipe and attach drain from shower to the drain line.
This isn't all that uncommon and in new construction, it's very common to have to cut out the slab to ajust the location of the drains.
Eddie
/ Broken Drain Pipe #6
If you just want to plug the drain get an expansion plug for it. If you want to fix it go Eddies rte..
/ Broken Drain Pipe #7
I agree with Eddie, chip out the concrete and then attach a new section of pipe and repour around the new pipe. May be a little dusty, but it can be done.
/ Broken Drain Pipe #8
Like Eddie said...moving a drain or repairing one is common in construction. Just be careful if you "dry" cut the concrete. Silica dust is not good for the lungs and a dust mask will not work. I would personally rent a wet saw and throw up some plastic on the framing members. It might be a little messy but it will be contained in the shower area.
/ Broken Drain Pipe #9
You don't even need to get to the main. As long as that broken stub is about 2.5"-3" tall, you can use a "hub-less connector" (Fernco coupling) & come up past the finished floor height in PVC. If that line to the right, in one of the pics, is what you are thinking of tying into, you may run into pitch problems, so coupling into the broken cast iron is likely easier/less work.
/ Broken Drain Pipe #10
Like others have said. Remove the concrete and do it right, or you’ll be doing it again in a few years. If it’s that bad above ground, who knows what it’s like underground. You need to get to good clean pipe, and work you way back up.
/ Broken Drain Pipe #11
Plugging it,,well who knows how far down it rusted into,,but plugging the end oughta be simple enough,,maybe stick a rag in it and fill with that expandable foam stuff,,or stick a rag way down in it and fill with a concrete of some kind,,maybe a rubber end cap,,,just gotta stop odor and water,,maybe its not in that bada shape futher down,thats the bad thing about concrete around lines,,maybe get you a jack hammer of some kind and have at it,,,but if you don't need that drain anymore,,,plugging it should be simple enough,,,thingy
/ Broken Drain Pipe
Thanks to everyone that replied with suggestions. I apologize for not getting back to this thread earlier. I have been almost too busy to check my email. I still haven't done anything but plug the pipe with an expansion plug. At present I am planning on installing a perforated sump and pump in the area adjacent to this so that I can relieve the hydraulic pressure under the house, and I will plug the pipe correctly when it is exposed.
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
UNUSED WOLVERINE RSB78-78" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
2024 Ford Explorer AWD SUV (A61574)
2024 Ford Explorer...
Challenger 35/45/55 Tractor Parts and Service Manuals (A63117)
Challenger...
