Broke caliper bleeder
/ Broke caliper bleeder #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I think the best way is to replace the caliper? It is 86 CJ7, calipers are original, rebuilt once in 99, I think new ones are in order anyway.
Better idea anybody?
/ Broke caliper bleeder #2
I've had broken bleeder valves and was able to get them out with an ez-out. There is already a hole in the broken one to use with the ez-out.
/ Broke caliper bleeder #3
Another option that sometimes works is to drive an allen wrench into the hole in the bleeder and use this to turn them out. Allen wrench isn't as hard and brittle as an EZ out. Use lots of penetrating oil and let it soak for awhile.
At that age new calipers may be a better choice.
Roy
I will definitely try to get it out, there is nothing to lose. Thanks, guys.
/ Broke caliper bleeder #5
Left handed drill bits work fairly well.
Nor-the-rn T**l has an assortment. I'm sure others do also.
Dave
/ Broke caliper bleeder #6
They also make repair kits for the bleeders, and oversizes, but as cheap as the rebuilt calipers are, a new pair would go on mine.
/ Broke caliper bleeder #7
Dave
LH drill bits work real well, the heat of drilling seems to help get the broken item moving...
/ Broke caliper bleeder #8
I've tried every penetrating oil and I have found Yield from chemsearch to be the best. We call it goat piss in the shop. It works!
That allen wrench sounded like a great idea, but this was apparently beyond fix. Will turn it in as core with part of the allen wrench:D
/ Broke caliper bleeder #10
the left over wrench will cost you . once you make it harder for the rebuilder they charge :(
Picked my parts from autozone, checked them briefly and later realized the caliper is for passenger side - i.e. the bleeder is lower than brake line input.
To make he jeep driveable I stuck a piece of wood in the caliper, twisted the caliper to put the bleeder above the brake line and pushed the air out following the normal procedure. Than I mounted the caliper and pads and drove to town to finally get the driver side caliper. When it comes, I will swap the old one on the right side for the one currently on the left and install a new one on driver's side. It is a PITA, but I will do anything to keep the jeep running.
/ Broke caliper bleeder #12
Maybe but most of the time when I return a core they don't look at them very well, sometimes they don't even look in the box!
/ Broke caliper bleeder #15
Too late for your situation but this worked for me about a month ago when I had the same problem. I tried easyout and That didnt work. I took a washer with the inner diameter about the same size as the bleeder or a bit smaller. I welded the washer to the bleeder with my MIG. I then welded a nut to the washer. All the heat from welding helped break it free. It turned out of there no sweat after that!:D This was the first time I tried this trick, been wanting to try it for a while. Ok, well nobody wants to do things like this unless they have to but you know what I mean.:thumbsup:
2018 Howden 24 URAI-B Rotary Lobe Blower with Utility Trailer (A61572)
2018 Howden 24...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
UNUSED SDLANCH SDLL60 STAND ON SKID STEER (A64280)
UNUSED SDLANCH...
ASSORTED STIHL POLE SAW PARTS (A62613)
ASSORTED STIHL...
2025 82in Rock Bucket Skid Steer Attachment (A61572)
2025 82in Rock...
