Briggs & Stratton Oil Filter
/ Briggs & Stratton Oil Filter #1
s78wingrider
Hardy Co. WV
Mahindra 3215 gear
Went to buy oil filter for my Craftsman mower (Husky) with 19.5 Briggs, and at Wal Mart was over $11. Anything else fit? Thank You Aaron :confused:
/ Briggs & Stratton Oil Filter #2
Look it up on eBay or go to your local parts house they will have a cheaper filter. Look for free shipping on eBay to save $$$
Several on there for around six bucks
/ Briggs & Stratton Oil Filter #4
There are many filters that cross reference to the Briggs filters. Just make sure to check the pressure relief valve spec to make sure it matches. If you have clearance you can basically use any one of them, but you might have to add more oil to compensate for a longer filter. The larger volume of oil will probably keep engine temperatures down a tad and be good for the engine, plus there is much more filter media, you'd have higher capacity, in all honesty they're probably better filters than the Briggs ones and cheaper too.
I use long versions of the filters in my Craftsman YTS4000 (Briggs 24HP) and Troy Built Horse (Kohler 22HP). I use sythetic media Fram gold ones in the Craftsman and they're less than half the cost of the Briggs filter (I run synthetic in this tractor now). I use Puralators on the Kohler and they're a third of the cost. Newer Craftsmans have reseigned hoods that will probably hit the very longest filters, might have to use something like an FL400s.
/ Briggs & Stratton Oil Filter #5
Aaron,
Here's a few. :) 3/4"x16TPI is one of the most common filter types out there. No need to pay $11 for one. For a typical 50 hours of service, any cheap automotive filter will be overkill. No need to buy fancy stuff.
As man114 pointed out, when cross-referrencing, it is YOUR responsibility to make sure it fits in the space provided. I would purchase one in a flip top cardboard box that is easy to return if the thread doesn't match or the can is too wide or long for your mower.
"Briggs type" filter: 3/4" X 16 threads 8-11 PSI Bypass
Gasket 2.734"OD 2.430"ID 0.226" thick
Kohler 12-050-08-S, 12 050 01, 12 050 01S
AC-DELCO PF2210 BALDWIN B1410
BIG A 92056 CARQUEST 85056
FLEETGUARD LF16108 GENERAL MOTORS 25313748
HASTINGS LF302 JOHN DEERE KH1205008
LUBER-FINER PH2814 MIGHTY PH2814
NAPA 1056 PUROLATOR L35310
QUAKERSTATE QS3614 TECUMSEH 36262
VALVOLINE L3512 WARNER PH2814
WIX 51056/51516(Tall) WIX 51056MP
STP S3512 FRAM PH8172/PH10960
Motorcraft FL400S(Tall)
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
2018 Ford Fusion Hybrid Sedan (A64557)
2018 Ford Fusion...
Trailmobile Van Trailer (A63689)
Trailmobile Van...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A65643)
2013 POLAR TANK...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
