Briggs has no spark.
/ Briggs has no spark. #21
My 2 cents, Check the keyway, replace ALL ignition parts. Double check magneto position. Nothing left to guess at. Good luck.
I put a new keyway in when I put it back together. I am going to take the points and condenser and magnito back to the place where I got them and get new ones. This is getting crazy. I need to finish this project.
/ Briggs has no spark. #23
A few things:
Is this engine in the tractor? If so, remove all ignition wiring and test just the engine. You might have wiring issues outside the engine. As stupid as it sounds - do you have the ignition switch off? I don't know what make or model tractor you are working on, and what the status of the project is.
Are the magnets on the flywheel magnetized? Could they be bad? Clean all rust off the magnets and the coil legs and regap to the proper clearance.
As for points, I'm not familiar with your engine, but are they externally mounted points, or internal under the flywheel? In any event, be sure the points are clean (use some ether) and then run a business card through the points to remove any deposits.
/ Briggs has no spark. #24
Don't give up hang in there.
Ok The magnet is good on the flywheel all new ground wires rebuilt motor rebuilt carb new plug new magnito condenser points, new keyway. What the heck is the deal. If the timming is out how would I fix it without going back into the motor? Also does anyone know anyplace that restores old briggs engines I would like to have them take a look at maybe a website to look at.
/ Briggs has no spark. #26
i FEEL YOUR PAIN!! I had a Kohler twin 16 that gave the same symptoms and purchased a new coil for it. As I was putting in the new coil and cleaning out the straw that the mice put in there i found a stripped wire off the stator that was shorting out. Fixed that up and have been fine since...Good Luck and let us know how you make out. It's probably something simple and you're looking at the more intense things..
/ Briggs has no spark. #27
I don't know where you're at, but here's a place on the net that has been helpful to me before. It seems pretty basic, and you may have done everything he suggests.
Jacks Small Engines. Lawn Mower, Tractor, and Small Engine Repair and Maintenance guide.
/ Briggs has no spark. #28
Try this website: Description and Schematics
this is what happens when I get fed up! ebay Item number: 110295517986
/ Briggs has no spark. #32
come on you can do better than that.
solve the problem watch a couple of video's on you tube I thought that last video shows how to test for spark while she all apart.
besides that price is high and you don't know what you will be getting in to with that.
if needed check out a couple of yard sales you would be surprised what you find out there.
Hang in there you can do it...
/ Briggs has no spark. #33
Thats a nice new motor you ordered. Solved all the problems. Let us know how it works out...
Yeah I got so mad today this has been goin on for 3 weeks and I got to get it done. I am going to reuse the old tank and the orignal delco remy starter that I just had rebuilt and the bracket. I will also reuse the flywheel. I talked with the guy today about the motor 2 year guarantee. So if it does not work I can send it back full refund. He is going to start it to make sure it runs before he send it out. I did not want to spend the money but now when I get the new motor I can spend the time and get the orignal motor running. So then I can use it on somethin else. The only reason I need to get this done so soon is I will be going to see my wifes parents over xmas and want it to be runnin for them.
Now should I buy a new flywheel or will the 6hp flywheel from the old motor work? the new engine is 11hp.
yeah 11hp same engine same size the orignial is a 6hp
Yeah it will fit it is almost identical in the demisions. I am concerned about the flywheel from the 6hp fitting the 11hp. The engines look exactly the same.
2012 JOHN DEERE 700K LGP CRAWLER DOZER (A65056)
2012 JOHN DEERE...
2019 Dodge Durango SUV (A66738)
2019 Dodge Durango...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
2011 TAKEUCHI TB153FR EXCAVATOR (A65056)
2011 TAKEUCHI...
2018 Toro Workman HDX-D Diesel Utility Cart (A66734)
2018 Toro Workman...
