Bridge 4's 2638 HST CAB B.S. and ?? Thread
   / Bridge 4's 2638 HST CAB B.S. and ?? Thread
Okay folks, took some pictures from the snow clean up today. Winds of 60+ so there was very little snow blowing going on, most pushing piles back and up. I was able to blow the entire last storm though, so I had some room. Not much left though!
I will say, I would never want a plow, I really think a push box on these tractors is the best front snow piece you can have. The ability to backdrag and hold a ton of snow on a long push is paramount for me. The only downside is curves, but it really isn't bad around curves, and if you go back over it after the initial clean up, it's easy to make that curve a straight line in places and get a nice clean up done.
Pictures are missing a big of what I do, but every storm is a few hours in the cab. Anything 4+ is about 4 hours of work, 8+ is 6-8 hours of work if its heavy. This little guy works hard for me, but it is constrained a little by it's lack of weight for big pushes of wet snow. I think some of you will be surprised on how much snow I move every storm with this 40hp beast though!
Also, replaced the wiper blades. The front was okay, but the rear was torn off in places and totally done. Not helpful on windy days snow blowing that's for sure.
I started a new thread asking about it, but they are a simple J hook, and the rear is 12 inches (I replaced with a 14) and the front I believe is 17 inches. Can get at any local auto part store, do not buy the OEM ones. 90 for the front, 80 for the rear from Bills, and that's on sale!:sick:
   / Bridge 4's 2638 HST CAB B.S. and ?? Thread #83
Glad you got your blades. I just came in from plowing about a foot. Been out since 8. I've been using the loader all winter but dug out my double auger blower and put it on to move some snow. Piles are 10-12' high. Last week we got 40" over a 2 day period. Another 40 expected today and overnight. I'm in the snow belt area 20 mi. SE of Lake Ontario. My tractor is only 36HP but its nice to be in a heated cab.
Dang, I thought we got some decent snow this year. I do not envy that! The heated cab is what makes me not mind being turned backwards most the day! Don't be scared to post some pics!
Thanks! The basement is a water storage tank for our sprinkler system, the ground floor is half pump room for the sprinkler system (john deere powered) and half commercial kitchen. Upstairs is a bedroom/bath.
   / Bridge 4's 2638 HST CAB B.S. and ?? Thread #88
Makes me wonder what the snow ratings are on some of the trailer roofs out there! Thanks for the photos.
The black enclosed trailer roof caved in 6 years ago. I rebuilt and braced the roof with stronger metal.
The camper had the roof removed by the camper dealer. I had them double up on all cross bracing.
The MH has stock roof.
I'm keeping my fingers crossed they hold up.
Another hitch! I've had an issue getting my hood opened up since this summer. It's always been tough, but it just wasn't happening anymore. Looked at youtube, did all the tricks etc... nothing. Bashed the hell out of it and that didn't help either!
Finally got fed up, and removed the front mesh below the latch, and then the two bolts attached to the latch. They are prob around a 10-9mm but I used an adjustable.
Anyway, still wouldn't budge with a screwdriver prying it and some PB blaster. I ended up cutting the latch off with a cutting tool, and ordering a new one from bills tractor.
I will have to keep up on the new one, keep it greased etc.... It had a small front end crash once, so that could have caused the problem, but it seems to be pretty common online looking.
Reason I am opening it in the first place, I got some new work lights! Picked up the new fancy ones from Harbor Frieght that compete with the Baja design lights. 100ish for each, vs 400 for the designer stuff. I have auxbeams on the back, and they work great, but I wanted to give these a shot. Blowing in the early mornings or overnight, I can't see a damn thing with the stock lights, so been wanting to do the front for a while. I replaced the rears a few years back and it was a huge upgrade.
I'll post some photos once it gets done.
Got the lights on! One is a spot/flood and one is just a spot. I thought I got two spot/floods, so that was a bit of a hiccup. I think it will be fine with how I will use this, and there is side lighting on both, so they basically are all floods at the speed I am going.
Will post up some photos showing the light tonight.
Wow! Okay, so two different ones. The right side is the flood/spot combo and the left is the spot. I think the spot/flood does a better spread and distance. I will be swapping back the spot for another flood/spot. The side lighting with these is great, I am really happy with these, it even lit up behind the tractor! Warranty at HF is easy too.
I ended up getting the second light switched over to a combo/spot too. I think the light output was significantly better for what I was looking for. A really wide and clear view will be great. Hopefully it doesn't wake the neighbors up when I have to go out at night.
If I timed things correctly, there will be no more snow this year and I won't use the tractor in the dark for another 8 months.
   / Bridge 4's 2638 HST CAB B.S. and ?? Thread #93
I wanted to make a thread that I could consolidate all my questions, any possible mods, and my reviews on implements I use etc...👍
I got a 2019 2638 w/Cab and HST dropped off yesterday, had 4 hours on it. I added 2 rear spools, and will add 3rd function later on. Got the quick hitch for the 3pt but need to put it on still. I've only got about an hour of seat time on the Mahindra so far. Before this I've used my father's Cabbed 90's JD and early 2000 Kubota, the JD is mid 50hp and the Kubota is low 40's. I like the Kubota the best, but the JD certainly was the go too for bigger things or pulling someone out in the snow.
I got this to primarily load a compost spreader during growing season to build my turf, plow and blow in the winter to keep parking lots and our driveways open. I also want to get a box blade/land plane eventually as well to clean up and smooth out my trails and old logging roads. The main reason I went with Mahindra was price, dealer location and this series seems to be reliable and well made.
Right now I only have an hour on it, primarily just playing around with loader bucket and getting used to the driving modes and seeing where I fit on existing trails. With the loader on the front, the rear tires have very little traction to push up hills or small brook banks. I need to find someone local who can fill tires, and get some rear implements going to balance out the weight. The loader itself seems to run very smoothly and I have been happy with it. The only thing I am not really concerned, but wondering about is the hydraulic squealing sound when accelerating, I've never heard that on other tractors? Am I running at a wrong RPM or not doing something? Or are these tractors just a little noisey? I've also noticed reverse isn't super smooth. I'm wondering if that's a result of my weight imbalance a little bit though as well.
Anyways, any tips or suggestions would be great. I did read the manual and actually found it somewhat useful despite what people have said on here. I will admit that for anything more complex than changing fluids, I'll be searching youtube for better examples. There were a few points where it told you to look at another section for information then it wasn't there.:confused3:
Anyways, so far I'm happy, and as I get used to operation and adjust to everything I'm sure I'll be even happier. :dance1: I have a 40 foot HC shipping container coming hopefully next week for storage.
Not sure why photo is upside down, and tips on that appreciated as well. View attachment 615600
Love the 4 cyl engine it actually has more cubic inches than my 2660 and the 60 is a 3 cyl turbo would have liked a non turbo because i dont like setting there when i get thought idle the engine for 3 to 4 min according how hard i work the tractor to cool down the turbo . I think you can correct your pictures by always having the button you mash to snap the picture in the right hand , try that.
   / Bridge 4's 2638 HST CAB B.S. and ?? Thread #94
I filled my tires with rv fluid and im pretty sure it took over 40 gal per tire to fillto top of the rim . I was very impressed with how much better my traction was and stability I have right at 190 hrs on my 2017 2538 and love it. wish i had rear remotes.
You can have one from Tractorinnovations.com go watch their u tubs and the kit cost $625 i am not connected with the company except i bought one of his kits his is a easy guy to work with.
I let mine idle down, and I let it warm up most the way before I work it. Even without turbos I try to baby it as much as I can on start up/shut down.
Replaced my broken hood latch. Took about 2 minutes and works like a charm. ***To replace, getting it off was a pain in the butt and I had to cut the latch from where it grabs the hood to hold it down. Probably should have done this a year or two ago.
Will try to avoid head on crashes and being rough on it from now on. The latch on the other was basically disconnected from the release and it wouldn't let go. Part number below for folks who might have this issue. Works on a couple of their tractors.
Picked up a part today to get my tractor to register I am using the brake pedal to get started.
Does anyone know WHERE these diagrams are showing? There isn't a bigger picture and I am only halfway handy. I am guessing its towards the cab where the pedal is, but i have no clue.
Thanks in advance.
In good news, my dealer got the part in quickly and said Mahindra has been getting their self together as far as parts availability in the last year or two.
   / Bridge 4's 2638 HST CAB B.S. and ?? Thread #98
I'm need of 2638 hst service manual. Tractor was given to me but front axle has to be replaced. Got the part just not sure how it goes back together
I believe I have it, if you pm your email, I should be able to send it over google drive.
Found the place this stop switch goes. It is IN the cab. I will post some photos and explainers later. Now that I know where it is, it looks to be a real clean swap. Just need a wrench and some dielectric grease.
2024 KAUFMAN LOPRO WEDGE 3 CAR TRAILER (A59905)
2024 KAUFMAN LOPRO...
2019 CATERPILLAR 289D SKID STEER (A60429)
2019 CATERPILLAR...
UNUSED RAYTREE RMVR76-76" HYD VIBRATORY ROLLER (A60432)
UNUSED RAYTREE...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2014 CATERPILLAR...
KUBOTA U25 SUPER SERIES EXCAVATOR (A60429)
KUBOTA U25 SUPER...
1449 (A57192)
1449 (A57192)
