brazing a hydraulic line
/ brazing a hydraulic line
the part is 250 bec. it's a solid line with fittings on both ends that are welded to the line. It's one continuous piece, and JD charges whatever they feel like apparently!! Fitting is pehaps a bad term.
It's part #11, near where bolt #12 is located. It's at the line to "fitting" where bolt #12 passes through.
I'll remove those bolt #12, remove the o-ring #1, and remove as much fluid as possible (if there is any in the line).
Wow, just realized it's been 20 - TWENTY - years since I last posted! I applied some JB weld and it held ok. Always some leaking but not much. It's leaking worse now, and figure since I have the hydraulic fluid drained down some, it might be a good time to try brazing. I'd try a simple torch with MAPP gas.
/ brazing a hydraulic line #24
I'm pretty sure Redrocker meant real silver solder. Typically you need less heat than brass which is nice for small/thin stuff. A welding supply should have it. If not a place that sells jewelry making supplies. It comes in several melting point temps. And it uses it's own kind of flux.
Right. Silver solder is the right stuff. You can use it along with a copper patch if you want. It does take some practice and the copper needs to be shiny clean.. The "easy" type SS takes less heat. I use SS a lot for various repairs but don't know if a propane/air torch gets hot enough.
The 15% HVAC rod?
/ brazing a hydraulic line #27
This will work. Many on here are confusing "solder" with "brazing". That line is probably SS, so this is what you want. I use 15% Staysilv or Silfoss regularly for copper brasing, or Safety-Silv 50 for dissimilar metals (copper/stainless).
The Amazon link is $15 per 18" stick. I'm brazing a metal hydraulic line. First time brazing.
/ brazing a hydraulic line #29
The JB Weld held for 20 years ... Clean it up, and mix up another batch!
Lol. Tempting. It "helped" but not "held". We'll see, but JB is plan B for sure.
/ brazing a hydraulic line #31
Maybe not the right way but on the spare Rhino tractor I bought this summer, the power steering pressure line had fractured / split for about 1/2" at a low point (thinking water intrusion when it was parked for around 15 years).
I closed up the gap after a good cleaning and flushing then filled the line with Argon /co2 welded it up with regular old .030" ER70S-6 using the HTP MIG. No leaks so far. IIRC it was just a steel line ie. magnetic.
/ brazing a hydraulic line #32
Brazing might hold for a bit, but it’s not a reliable fix for a pressurized hydraulic line. The heat can weaken the metal or make the leak worse later. If it’s at the fitting, the safest move is to replace or reflare that section. It’s pricey, but better than having the line burst under pressure.
/ brazing a hydraulic line #33
Silver solder is common practice for attaching hydraulic fittings to tubing. Unless its a flare with a backer, most likely the original fitting with soldered to the tubing.
Sent from my SM-S921U using TractorByNet mobile app
/ brazing a hydraulic line #34
A welded joint that brakes isn't where things like silver solder work very well.
As you are trying to repair a butt type crack vs sweating a slip joint for bond, like this.
For a crack in a welded connection, I'd go over it again with silicon bronze rod and a TIG welder.
Good for sealing and a much stronger joint.
I need to be able to use a simple Bernzomatic trigger start torch with mapp gas. Also I'm hoping to just remove the fitting from the pump, blow out some fluid, and work on it while the opposite side stays connected to the tractor. Post #22 above has the diagram. It'll be tight quarters.
/ brazing a hydraulic line #37
I use oxy/acetylene because it burns really hot, and have never tried silver soldering with Mapp gas by itself. Mapp gas paired with oxygen would be certainly work. Whatever you use has to heat the tubing, patch, and the silver so that the silver will flow along the tubing and under the patch.
I've heard that straight Mapp gas will work with silver solder only if you are using the lower melting point type of silver solder - which is called "low" or "easy" sillver solder -and forms a brazed bond at about 1400 F. But that should work.
BTW, silver soldering is really a type of brazing. It is not at all like tin alloy plumber's solder which flows at 400 to 600 F. I don't know why "silver brazing" ever got to be called "silver soldering", but it is.
Might as well get some scrap and practice first. It is often easiest to silver braze a patch made of a split piece of similar size tubing onto the hydraulic tubing. You might even try some copper tubing for the patch. Make it fit really well and clean and flux the cleaned metal before brazing it. Or you could get some copper wire and wind it around the tubing and then flow the solder onto that wire. With clean copper, flux, and enough heat the silver should wick along the tube and under the patch and all but disappear. If it flows that nicely, you know the joint is good. The patch helps reinforce the silver. It is easier to patch tubing than to try to just cover a split with solder.
Silver solder rod and flux is kinda expensive.
If you know a refrigeration repair shop, they tend to use a lot of silver solder & might sell you a single rod. Get a lump of their brazing flux, too. You can mix the flux with water if it dries out.
rScotty
If you know a refrigeration repair shop, they tend to use a lot of silver solder & might sell you a single rod. Get a lump of their brazing flux, too. You can mix the flux with water if it dries out. I think the leak is right at the line to fitting connection. It's a tiny leak - a drip every 5s.
rScotty
Thank you. The HVAC rod looks to be 15%, whereas the other is 56% or 45%.
/ brazing a hydraulic line #39
I used the 56% to make up some hyd. fittings, I used oxy/acetalyne. It definitely takes some heat for it to flow, not sure if the straight mapp is going to do it, depending on the fittings mass.
Do you have a picture of the leaking area? Your initial post made it sound like the joint is leaking rather then a hole in the line. If so a patch is not needed.
/ brazing a hydraulic line #40
The 15% Stay-Silv is good for copper to copper brazing. If you are doing steel, brass, stainless steel, or any of those materials to copper or to each other, you'll want the higher silver percentage brazing wire. I typically use Safety-Silv 50N. The Safety-Silv 56 should also work fine, although I think the 50N has better gap filling properties and will work better if you don't have a tight fit between surfaces. I always use the Harris white flux, although the black flux is recommended for use on stainless steel. When brazing steel, you need to be careful about not overheating the base material. If you see the steel get to any sort of "red hot" you have gone too far. The steel surface will scorch, and the silver braze will not stick to it. If you get there, you'll need to wire brush or sand the surface back to clean metal before re-fluxing and starting over again.
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
2015 PETERBILT 579 (A65643)
2015 PETERBILT 579...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
Vermeer 6020 3 Point 8ft. Disc Mower (A65640)
Vermeer 6020 3...
