Branson hydraulic problem
/ Branson hydraulic problem #1
big country
I have a Branson 3550 4wd w/front end loader.My front end loader will not lift nor will the rear pickup. I have removed the quick disconnect line from the contol valve and can push the ball in and fluid slowly runs out until it starts blowing air and then the pump finally kicks in, but now there is so much pressure on the line I have to turn the tractor off to get the line back on. Sometimes if I am quick enuf it will keep pressure but most of the time it wont. Any ideas?
/ Branson hydraulic problem #2
Well first off don't run the engine with the quick connects disconnected. That is an open center system, which means that the fluid has a open/low resistance pathway all the way thru the valves and back to the sump with everything connected. High volume flow, low pressure, untill a valve control is actuated and fluid is sent to a cylinder(lower flow, higher pressure, work is performed). Hydraulic fluid must always flow in these systems. By separating the QC's, you are most likley deadheading the pump. This is very bad for the pump, seals and hoses as there is no flow and extreme pressure, and no safety to vent the excess pressure that builds immediatly when the flow stops. Pump cases crack, seals and hoses blow, pump shafts twist and break, ect...
It sounds, from your description like your pump is loosing it's prime or sucking air. Check all the suction line fittings between reservoir and pump. It is very easy to suck air in a leak on the suction line instead of sucking oil along the line. You could also have a clogged suction line strainer, usually locatd where the suction line gets it's oil from the sump. You could also be low on hydraulic fluid in the reservoir. If you find no problem with the suction line fittings, strainer or fluid level, it is possible that you have a damaged seal or cracked case on the pump that is admitting air on the pump body or around it's drive shaft.
2022 EZ-GO ELITE...
2011 INTERNATIONAL WORKSTAR 7300 CHEMICAL BOBTAIL (A65643)
2011 INTERNATIONAL...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
More info coming soon (A61574)
More info coming...
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
2022 EZ-GO ELITE...
