Brakes required?
/ Brakes required? #21
were they making them retrofit trailers that were previously legal? IE.. florida used to only require 1 brake axle on a tandem.. now requires both.. but afaik all the old tandems with 1 brake that were legal at the time of manufacturer are grandfathered in.. kind of like the seat belt thing.. vintage cars that never had em are granfathered and don't have to retrofit them..
soundguy
/ Brakes required? #22
It is my belief that ANY trailer that causes the tow vehicle's GVW to be exceeded needs brakes on all axles, period, no exceptions.
This allows larger pickups and trucks to pull heavier trailers IF they are otherwise un or lightly loaded and would essentially require brakes on every trailer pulled by small cars that do not have the braking capacity for even a 1,000 lb trailer if the driver is in the seat :)
/ Brakes required? #23
That doesn't really makes sense. One should never be exceeding the tow vehicles GVWR with a trailer.
/ Brakes required? #24
I think what he is saying is the GVWR is that of the truck. For example my F-350 is 11,500 and the truck weighs 7,600 so you could pull a trailer upto 3,900.
The GCWR is 24,000 so I can pull upto a 16,400
Chris
/ Brakes required? #25
GVW = GVWR; Gross Vehicle Weight (Rating)
GCVW = GCVWR; Gross Combined Vehicle Weight (rating).
Diamond is 100% correct, the ability to add a 10K trailer to an 8k pickup (GCVW = 18k) does not imply the ability of the towing vehicle to STOP 18k, only that it can pull and control the direction. But, if your 8k pickup weighs 4k empty, then technically you *could* pull a 4k brakeless trailer w/o being overtly dangerous.
OTOH, a typical 4 door sedan with a GVW of 5800# that weighs 3800# empty cannot safely pull even a 2k trailer w/o trailer brakes. The weight of even the driver and a full tank of fuel puts you WAY over the GVW.
That's why, IMO, it should be a HUGE FINE if you exceede the GVW of ANY vehicle in terms of braking capacity.
/ Brakes required? #26
soundguy
Highway Patrol told me the same thing when I asked... one of my trailers is rated for #3500 and was built in 1964... before the #3000 requirement for brakes...
I own and restore antique cars... my oldest is 1905 and is legal without any of today's requirements.
/ Brakes required? #27
I'd think it would almost have to be that way.
soundguy
/ Brakes required? #29
You guys in the US have it easy!!!
Here in Europe the limit for no brakes is the lower of 750Kg (1650lbs) or half weight of towing vehicle.
Brakes tend to be overrun - when vehicles brake, trailer pushes against a spring on headstock that applies brakes by cable. Some mechanics in the hubs prevent the brakes being applied when reversing. The maximum allowed on an overrun brake trailer is 3500Kg (7700lbs) - above that it needs powered brakes.
Not only that, but new drivers are allowed a maximum weight of car and trailer of 4250Kg (oldies like me are allowed 8250Kg) on a standard driving license.
J
This is cause you guys over there drive bubble cars. I have seen some of the things that europeans tow with on you tube. These videos were not making fun of the tow vehicle/vs. the load, they were boat videos making fun of the stupid things or no skill that the driver was doing. Ie. can back down, get boat off trailor or onto trailor.
/ Brakes required? #31
yikes... couldn't even tow one of my big tractors with those low tow weights...
soundguy
/ Brakes required? #32
Looks like my state requris brakes if the ''towed vehicle'' meets or exceeds 3000#.. It doesn't say if required on both axles or 1 .
I'll have to call the DOT & ask . If I'm able to talk to someone that has enough sense :laughing:to find that info.
/ Brakes required? #33
soundguy
It causes lots of problems for many vendors.
There are only one or two trailers that weight less than 700Kg to legally carry my Takeuchi TB125 @ 2800Kg. Even then, buckets, fuel, tools etc all have to go in the towing vehicle.
Kubota have a similar issue with the 2800Kg KX71 - so much so in Europe there is a smaller machine called the KX61 (built in Netherlands I understand) which weighs only 2600Kg giving that extra 200Kg payload for buckets, tools etc.
For those of us on pre-EU driving licenses, we can drive 7.5 ton gross weight lorries which will carry up to KX121 / TB135s and bits - but buying a lorry just to move a digger is a PITA for non-commercial people (although my daughter would probably like me to buy one with a demountable horsebox!).
As I said in my first post, you guys in US (not sure about Canada) are lucky!
J
/ Brakes required? #34
I wonder why so much regulation on towing over there?
soundguy
/ Brakes required? #35
J
I recognize lots of yalls terms like lou , bonnet, petrol, from just hearing and shows like house hunters international on HGTV, but what the h#!! is a Lorry? Horsebox? I fugure a horsebox is just a livestock or specialized horsetrailor, but there some crazy terms there considering we are speaking the same language. I figure a Lorry from context must be a dumptruck or a box truck.:confused2:
As to what soundguy said, what is the deal with letting some guy not tow his backhoe with a F-350 and a 10,000lb gooseneck trailer?
-nate
/ Brakes required? #36
yep.. lorry is a truck essentially.. like a box or cargo truck.
here's the definition shamelessly pulled from wiki:
"A truck (American English) or lorry (British English) is a motor vehicle designed to transport cargo. Trucks/lorries vary greatly in size, power and configuration, with the smallest being mechanically similar to an automobile. Commercial trucks/lorries can be very large and powerful, and may be configured to mount specialized equipment, such as in the case of fire trucks and concrete mixers and suction excavators. Modern trucks are powered by either gasoline or Diesel engines, with the latter dominant in commercial applications".
/ Brakes required? #37
@soundguy
Regulations on everything, sadly. Someone once said to me in UK you can do anything not expressly banned - however in Europe you can only do what is permitted. Not sure how true that is - but certainly what is more and more widely regarded as the EUSSR is trying to control more and more of life (assisted by some pretty dodgy local politicians).
@ nate
Lorry - I guess you would call them a truck - in this case a 7.5 ton, twin axle truck - however lorries tend to be the equivalent of your bigger trucks - we still would say a pickup truck, not a pickup lorry, for example for smaller vehicles.
Horsebox - yes, you guessed, a box on the back of a lorry for carrying horses.
The variations in english are always fun. I work in IT and computer networking - and we talk of routes and routing tables as in the network directions to get two computers to talk to one another. Route in UK is normally pronounce "root" - and a routing ("rooting") table to an Australian has an entirely different meaning!!!!
J
/ Brakes required? #38
soundguy
It depends on how the trailer is used, in the example of the lawn care guys they were using it in commerce so it is considered a commercial vehicle.
Some manufacturers still sell tandems with only brakes on one axle, that is fine for the guy using it to haul his own stuff not in commerce. But once he uses that trailer for monetary gain he is considered a commercial vehicle.
/ Brakes required? #39
I can not speak for your state, in MN if you are not in Commerce you only need them on one axle, if in Commerce you need to follow the federal regulations that requires them on all axles.
/ Brakes required? #40
i guess non comercial loaded trailers weight less than comercial loaded trailers so them pesky extra brakes aren't needed.. :)
some laws DO make ya wonder..
soundguy
2022 EZ-GO ELITE...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
2014 Takeuchi TS50R Compact Wheel Loader Skid Steer (A61572)
2014 Takeuchi...
2021 John Deere S790 Combine (A63111)
2021 John Deere...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2006 GMC C5500 4X2 BUCKET TRUCK (A59912)
2006 GMC C5500 4X2...
