Brakes explained???
/ Brakes explained??? #1
BILLMAN
MARYLAND
KUBOTA 7500 HSD
Can you guys explain how the brakes work on my B7500. This is my first tractor. I am very familiar w/ automotive brakes but, I sure don't see anything that looks familiar to me. Wet discs? Share the gospel w/ me. Is it OK to mention a B7500 or will TresCrowes get upset?
/ Brakes explained??? #2
<font color=blue>Is it OK to mention a B7500 or will TresCrowes get upset? </font color=blue>
I read on another post where he recommended a fellow take a look at the B7500. I'm not sure he was sincere or feeling well/w3tcompact/icons/wink.gif
The brakes are contained in the rear axle case and each consists of two brake discs and a friction plate between the discs splined with the differential gear shaft. When the brakes are applied a cam plate is forced against the discs and braking is by friction force between the discs and cam plate. All this stuff is emersed in transmission oil and should last a very long time if you don't forget to disengage them to often when running the tractor. I'm not sure if the BX has brakes/w3tcompact/icons/wink.gif
Al
/ Brakes explained??? #3
<font color=blue>I'm not sure if the BX has brakes</font color=blue>
I thought you just put your feet down and dragged your heels. /w3tcompact/icons/wink.gif
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
JOHN DEERE Z515E ZTRACK ZERO TURN MOWER (A65054)
JOHN DEERE Z515E...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2022 EZ-GO ELITE...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
