Brake shoe replacement question
/ Brake shoe replacement question #1
Deere Dude
Elite Member
Beaver Dam Wisconsin then to Hohenwald, TN
John Deere 3720
I have a pretty new trailer, 2-7000# axles with 12x2 brake shoes. It has 2 Rockwell American axles with electric brakes.
I rode it pretty hard for a year and am redoing the brakes now. One time the ripcord pulled out and I pulled it for 12 miles before I realized what was happening so it got a good breaking in. :ashamed::ashamed: Thanks to my Duramax. The trailer has about 10,000 miles on it and it doesn't seem like I can get any adjustment out of the star wheel to tighten the brakes any more.
I know I need one magnet and was going to take the other hubs off tomorrow and was wondering where to get parts for that thing.
Napa and Reilly and AutoZone places don't have shoes and magnets etc. for that brand, unless everything is interchangeable.
I looked at etrailer.com and it seems to me that a complete set of shoes and magnets etc. are a lot cheaper than buying parts individually. I looked and they had Dexter and two other brands in my category and was wondering if those brake sets would bolt on to my Rockwell American axle and in my hub.
I hate to buy all kinds of stuff only to find out they won't work.
Everyone I talked to didn't seem to confident in their answer so I thought I try you guys.
Thanks
/ Brake shoe replacement question #2
lookup user diamondpilot. he does lotsa trailerwork. might be able to help ya.
good luck!
ps.. don't feel bad about the brake test.. just about everyone here has had some sort of e-brake torture test :)
I was pulling a tractor out of texas on a small 16' flatbed, ran over a hunk of tire that snatched out my trailer plug.. I didn't notice the 'NC' on my controller telling me no connection, for about 5-10 miles. in that time.. the trailer plug drug and ground off about 25% of it. had to pull over in freezing weather and me and my driving buddy went at it with zip ties, electrical tape and some bailing wire to jumper connections over so we could make it back to florida with brakes and lamps!
so yeah.. I now safety zip tie ( they are cheap.. i buy em in bulk at work.. ) my trailer plug to the socket EVERY hookup.. don't care if it is down teh road to the neighbors house... ;) I keep a wad of 100 ties in a piece of pvc that is strapped to the trailer frame. 2" pipe and 1 glue on cap and 1 slipped on cap makes a good storage for the ties.. always got some when needed... never drag a plug again!
/ Brake shoe replacement question #3
Here is the Rockwell site for parts. I imagine Etrailer sells them also but could not find Rockwell axles listed. DiamondPilot does a lot of trailer work, Maybe he will pop on and help you out.
I replaced mine last summer and bought the entire kit from the backing plate out from Etrailer.
Brakes and Components
/ Brake shoe replacement question #5
I found it MUCH less expensive to buy whole backing plates loaded with shoes, magnets, and all adjusting hardware than it was to replace individual parts.
Whole backing plates shipped free (i couldn't believe it either) from E-trailer.
Its my understanding that if they are 12x2 backing plates they will fit your drums no matter what brand. The parts have been standardized, which is to say, dont worry about trying to replace the individual parts, just bolt on backing plates and they will work fine with your existing drums.
I also did rear seals but my bearings were good.
my axle rebuild thread
http://www.tractorbynet.com/forums/...on/280114-axle-brake-rebuilds.html?highlight=
/ Brake shoe replacement question #6
I found the same thing.... cheaper and easier to replace the whole plate than buy and install individual parts. Used solder and shrink tubing. Stay away from the press together connectors. Weather eventually gets to the connection. Had 5000 pound axles, upgraded to 7000 backing pound axle plates. The difference is in the magnets. Much more powerful braking action.
I got on etrailer.com and for the size I need, a 12x2 @7,000# there are about 5 or 6 different companies selling the same thing. But I am sure there are differences in overhead and price structure causing the prices to vary from $45 to $90. I noticed a "never-adjust" one for $75. It seems after listening to you guys they all should work, so I need to read the reviews, and all of them seem pretty satisfactory, and try to find differences that might influence me. Is a $90 one made by Hayes as good as a $45 one made by TruRyde or a $73 assembly by Dexter?
The shoes I saw today on mine sure seemed cheap and thin. I don't think they were 1/8" thick. I thought they would have been 1/2" thick even after using them for 10,000 miles.
I suppose if I only use the trailer a few times a year going forward, a cheap one will be fine.
Thanks for your input.
/ Brake shoe replacement question #8
We deal with off brand axles all the time and the parts seem to interchange. I agree with the others and just get all new backing plates. I always start at R&P.
Chris
I took all the drums and had them cut and am ordering all new backer plates, the cheaper ones. But, the face that the magnet rides on is a little rough. Nobody here surfaces them like I would want. A fairly new friend is a machinist and has a lathe at home. He is going to take a look at them Wednesday to see if he can do anything with them on his machine. Should that work?
I have a neighbor who has a smaller handheld grinder that he said should work. It wouldn't make the surface flatter but it might get rid of the imperfections. He said he would sand it with a course grit and go finer until it's about right.
/ Brake shoe replacement question #10
We throw them away when they get that bad. Time/Labor simply outweighs the cost of new ones. If you can get it done for free might be worth a shot but my gut says you'll end up buying new sooner or later.
Chris
/ Brake shoe replacement question #11
Bought the last new set for the camper from trailerparts superstore and the complet kits were much cheaper than just the shoes and they came right in Dexter boxes too.
/ Brake shoe replacement question #12
Little late here, but my local NAPA crries everything, including complete backing plate with magnet, shoes etc.
Have a couple supply/repair shops in the greater area that has everything too.
If you tow 10,000, are you doing bearing repack and/or replacement? Dexter says to repack them 12 months or 12,000 miles.
I have about 10,000 miles on it and is 1 year old. I am repacking the bearings. I ordered the backing plate set-up from etrailer.com. I checked Napa and Reilly's but wanted a specific company brand which they couldn't get. I didn't know at the time that this stuff was interchangeable.
The only thing now is if I can get the magnet faces perfect. If I cannot, oh well, maybe next time. I used this trailer for a bunch of trips from Wis. to TN and now I am done with the move. I may put on 1000 miles in the next year, but don't expect much more than that.
It has been a month since my GN brake job which turned out okay but haven't run it down the road yet because I need to change hitches in the truck because I have the camper hitch in it now. I decided to do a brake job on my camper right away because of the GN success story and because I haven't looked at them in maybe 20-30,000 and also because they don't seem to stop adequately plus seem to run to warm, except for one corner.
The axles are 8,000# and have 12-1/4" x 3-1/2" shoes so they are heavy duty, at least to me.
Three backing plates and shoes on the warm running corners looked sort of okay. The shoes had about 1/4"+ shoe left. The corner where it ran cool to the touch only had 1 shoe on and that was at least 1/4 to 3/8" thick.
What in the heck happened to the other pad???? The metal was there and rubbed on the hub doing a little damage, but no pad. :confused3: I do remember having one leaky corner worked on 10 years ago, but don't remember exactly which one. Was it bad from the factory or the camper dealership??:confused3:
I wanted to change all the magnets but magnets were half the price of the whole assembly, so I ordered all new assemblies and am having the hubs cut this morning, even though they looked fine, except where the magnets rode.
This is just an update for my buds.:dance1:
/ Brake shoe replacement question #15
I've seen them separate before and all that is left is the backing plate. Not common but it does happen.
2025 Spirit Scooter (A64557)
2025 Spirit...
2017 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2017 INTERNATIONAL...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64278)
KNOW BEFORE YOU...
2014 Peterbilt 337 S/A 18ft. Cab and Chassis Truck (A64194)
2014 Peterbilt 337...
11in. Bucket w/ Teeth Excavator Attachment (A64194)
11in. Bucket w/...
