CoyPatton
- Joined
- Aug 10, 2015
- Messages
- 1,656
- Location
- Poplar Bluff, MO
- Tractor
- Yanmar YM2002D with Koyker 110 FEL
If wishing to level material, you really need it to a few inches wider that the outsides of your rear tires (typically wider that the front ones). Otherwise you will ge in a constant battle after your first pass, 1 tire will be on ground you have removed while the other will be on higher ground, this just to avoid leaving a narrow strip that you must come back to work and guessing ad to how deep to dig when leaving that narrow strip.Interested in box blade, using it for a plethora of projects and will be pretty rough with it. I have a 2008 ck35hst. Want to know should I buy a unit that is a few inches wider than the tires or go narrower, I have read differing opinions on the subject. I think a heavier unit is the way to go, need a unit that is built sturdy. I am leaning towards a unit that is hinged and was wondering if it's worth the extra money? Seems as if it would be. Again I will be using this for ripping and leveling, spreading gravel etc.,etc.
this may make limited difference to you on non m-ground engaging implements but is huge on ground engaging or material moving implements.
