Box Scraper Box Blade
/ Box Blade #1
billsh96
Northern Michigan
2008 BX 1860
I just saw a King Cutter box blade up the road for $300.00. Condition is real good. Looks to be about 60 inch wide. Is my BX 1860 enough tractor for this attachment? If I could buy it for $250, I think it would be a deal but don't want an impliement thats to big for the tractor.:confused:
Bill
/ Box Blade #2
I have a BX24 with a 48" box blade. With the scarifiers down, the 48" is all it can handle. I think others will agree that the 60" will be too big for serious digging. It will make a good rear ballast, though.
/ Box Blade #3
My 5ft KK box blade works well behind my 27hp / 3,750lbs JD 790. If i am not paying attention and cut to deep that box blade will stop the tractor in it's tracks.
If you got it for $250, tried it and it did not work you could resell it.
/ Box Blade #4
I would agree 60" is a little to much for that tractor, my previous B7500 could only handle the 48" KK with the rears filled.
/ Box Blade #5
I have a 60" box blade on the back of my BX23...I've used it mainly for my 1,000' gravel driveway and it's worked well...Don't think I'd try using it on hard pack though.
Don
/ Box Blade #6
Agree that 48" is max for a bx box blade. That way you can feel free to adjust the cutting angle, lower the teeth etc. as needed to do a good job. I have the Woods 48", and I love it. Second to the loader, it's the implement I use most. I sold my rear blade, because once I bought the box blade, I had no use for it. Of the two, the box blade is the more capable, useful tool.
Best of luck!
/ Box Blade #7
Bill
I couldn't say but if you were closer I'd buy it off of you if it didn't work and use it behind my M4800:D
(5) JOHN DEERE WEIGHTS (A63290)
(5) JOHN DEERE...
SHOPBUILT HAY FEEDING WAGON (A63290)
SHOPBUILT HAY...
2006 Chevrolet Silverado 1500 Pickup (A63116)
2006 Chevrolet...
2024 Bobcat T740 Track Loader (A63109)
2024 Bobcat T740...
2011 John Deere 1770NT Planter (A63109)
2011 John Deere...
2023 John Deere Z930M Zero Turn (A63116)
2023 John Deere...
