Box Scraper Box Blade
/ Box Blade #1
billsh96
Northern Michigan
2008 BX 1860
I just saw a King Cutter box blade up the road for $300.00. Condition is real good. Looks to be about 60 inch wide. Is my BX 1860 enough tractor for this attachment? If I could buy it for $250, I think it would be a deal but don't want an impliement thats to big for the tractor.:confused:
Bill
/ Box Blade #2
I have a BX24 with a 48" box blade. With the scarifiers down, the 48" is all it can handle. I think others will agree that the 60" will be too big for serious digging. It will make a good rear ballast, though.
/ Box Blade #3
My 5ft KK box blade works well behind my 27hp / 3,750lbs JD 790. If i am not paying attention and cut to deep that box blade will stop the tractor in it's tracks.
If you got it for $250, tried it and it did not work you could resell it.
/ Box Blade #4
I would agree 60" is a little to much for that tractor, my previous B7500 could only handle the 48" KK with the rears filled.
/ Box Blade #5
I have a 60" box blade on the back of my BX23...I've used it mainly for my 1,000' gravel driveway and it's worked well...Don't think I'd try using it on hard pack though.
Don
/ Box Blade #6
Agree that 48" is max for a bx box blade. That way you can feel free to adjust the cutting angle, lower the teeth etc. as needed to do a good job. I have the Woods 48", and I love it. Second to the loader, it's the implement I use most. I sold my rear blade, because once I bought the box blade, I had no use for it. Of the two, the box blade is the more capable, useful tool.
Best of luck!
/ Box Blade #7
Bill
I couldn't say but if you were closer I'd buy it off of you if it didn't work and use it behind my M4800:D
2017 PETERBILT 579 DAY CAB (A63569)
2017 PETERBILT 579...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63118)
2023 Kubota U48-5...
2015 FREIGHTLINER CASCADIA T/A 6X4 SLEEPER TRACTOR TRUCK (A59910)
2015 FREIGHTLINER...
2007 International 8600 Parts Truck (A63118)
2007 International...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63118)
2021 Gehl RT215...
