bound range shifter
/ bound range shifter #1
tyljs68
mcormick x50
have a mccormick x50 that the range shifter is bound, does anyone have a quick fix other than removing the cab and top of trans to get it to shift, TIA
/ bound range shifter #2
I'm guessing it's not just a matter of driving in 4WD on pavement and binding up the gear train as the difference between the "lead" on the front wheels (typically a few % higher ground speed than the rear wheels) can "wind up" the gear train when driving on surfaces that don;t allow some slip. If that's the case, try backing up a a few feet or more, if your last movement was forward (or vice versa). Also best to avoid tight turns in 4WD when driving on surfaces which don't allow some slip of the wheels.
Usually, this can bind up shifting out of 4WD, but I've had it bind up my range shift as well.
