Bought Spike Tooth Harrow . . .
/ Bought Spike Tooth Harrow . . . #1
mark.r
Platinum Member
Leesburg, VA
Kioti DK45SE
I picked one up primarily to cut up, and spread all the horse manure in my pastures. I finally got around to using it this morning and it worked well to do just that as well as detatch and "turn over" the dead grass. The 45 of course doesn't even know its back there even with the teeth set on the most aggressive setting. Now we just need some rain!!!
/ Bought Spike Tooth Harrow . . . #2
mark.r
Can you post a more upclose pic(s) of the hitch portion? Mainly the top where the chain hooks. Also, what size chain did you use? I've got a four bar 8' piece that I haven't made a 3pt hitch for yet.
Thanks,
bjepple
bjepple said:
mark.r
Thanks,
bjepple
I can take some pictures in the next day or so. I don't know what size chain it is sine came with the unit. But it looks like your typically semi heavy duty Home Depot chain.
/ Bought Spike Tooth Harrow . . . #4
I made a poor mans version a long time ago and you will love that one
Jim
/ Bought Spike Tooth Harrow . . . #5
The chain is 1/4" and where it goes through the plate at the top is a 5/16" x 1" slot. You put the link through and then use a 1/4" linchpin to keep the chain in place. Sorry, I don't have a close up of the hitch either.:eek:
bjepple said:
mark.r
Thanks,
bjepple
Here you go, hope this helps.
/ Bought Spike Tooth Harrow . . . #7
Thanks a lot, that's just what I wanted to see.
bjepple
bjepple
Glad I could help.
NEW Landhonor Diesel Fuel Transfer Pump (A62679)
NEW Landhonor...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A59914)
2015 FREIGHTLINER...
2010 WABASH 53X102 REFRIDGERATED TRAILER (A59914)
2010 WABASH 53X102...
100 Gallon Plastic Tank (A65640)
100 Gallon Plastic...
207923 (A63290)
207923 (A63290)
