Boomer Class III PTO Question
/ Boomer Class III PTO Question #1
DVerbarg
Platinum Member
Valrico, FL
No longer have :-(
Is the PTO on a Hydro Boomer Class III driven by gears or is it hydraulic? Just got to wondering. While using a post hole digger the auger stopped at one point, the tractor engine lugged but kept running. Real quick I pulled up but it got me to wondering if there was a clutch involved somewhere then it occured to me (I'm slow sometimes) that it might be hydraulic. Is the PTO on a gear Boomer also driven the same way? Is there any advantage or disadvantage?
/ Boomer Class III PTO Question #2
The PTO on class 3 boomers is a clutch pack this should give you a better idea. By this attached picture
/ Boomer Class III PTO Question #3
I'm pretty sure it is gear driven although I can't explain your experience. Did you break a shear bolt? Perhaps your clutch was slipping. I imagine there are advantages and disadvantages. Advantage: more efficient transfer of power. Disadvantage: not reversible.
An auger off the back of a tractor is an awesome display of power. When mine is digging it shakes the ground for a good 2' around the hole (especially when it hits a rock). Makes you really respect the power of the machine.
Peter
/ Boomer Class III PTO Question #4
let me clarify it is gear driven on 12x12 transmissions, but a clutch pack on hydro transmission. As you can see on the previous picture I attached. I am sorry the quality is not that good. The parts program we have does not like to be copied very well.
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
UNUSED FUTURE TP25-25" HYD TREE PULLER (A60432)
UNUSED FUTURE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2023 CATERPILLAR 972 WHEEL LOADER (A60429)
2023 CATERPILLAR...
