Boom Pole (first build)
/ Boom Pole (first build) #1
petergreen
Spain, Europe.
Lamborghini R1.40
Hello friends!
I'm new to welding. I learned just a few months ago, and I just finished my first "serious" build: a boom pole.
What do you think? I designed the thing myself, just looking for photos that people upload to the internet.
I've tested the thing by lifting my tiller (It weighs about 200kg, I think). It seems to hold. I'm happy!!!
/ Boom Pole (first build) #3
Peter;
Nice build but, you should look into rated lifting slings or chains.
Thanks for sharing.
Peter;
Thanks for sharing.
Yes, those belts got some beating that day. I have a heavy-duty chain for lifting work now. Better safe than sorry!!
/ Boom Pole (first build) #6
Looks very strong. To really test it chain it to an immovable object and max the 3 point capacity. Bet it will take it.
/ Boom Pole (first build) #7
Actually, I think the boom will bend at the point of the braces with a heavy load, or where the hole is in the side of the boom with a hanger..
What you need is a back bone setup where you add a 6 in riser at the brace point. Then a section of rebar from the 3pt pin across the 6 in riser and then on to the tip.
Is the tubing 1/16 in or 1/4 in?
Like this maybe.
Like this maybe.
Thanks, J_J, for your suggestions. I'll do that. Tube is 5cm (diameter).
/ Boom Pole (first build) #12
For those that don't know. 5cm = 131⁄32in
What is the wall thickness?
A good boom should be at least 2 in tubing or more and 1/4 in wall thickness.
1/4in = 41⁄64cm
2in = 5.0800cm
1/4in = 41⁄64cm
2in = 5.0800cm
I think thickness is 4 - 5 mm (1/4inch =~ 0.6mm)
/ Boom Pole (first build) #14
Actually, I think the boom will bend at the point of the braces with a heavy load, or where the hole is in the side of the boom with a hanger.. What you need is a back bone setup where you add a 6 in riser at the brace point. Then a section of rebar from the 3pt pin across the 6 in riser and then on to the tip. Is the tubing 1/16 in or 1/4 in? Like this maybe.
JJ;
What is the device, on the end of the boom, in your picture?
Thanks
/ Boom Pole (first build) #15
Hello friends!
Nice build!! Would make loading your tiller onto a trailer or anything else easy. I'm impressed with how it looks
/ Boom Pole (first build) #18
The attachment on the end of my boom is a tree snipper, limb snipper, limb cutter. etc..
Can reach up about 16 ft.
I can install it in any position to cut small trees horizontal, upside down to cut roots, etc.
/ Boom Pole (first build) #19
The attachment on the end of my boom is a tree snipper, limb snipper, limb cutter. etc.. Can reach up about 16 ft. I can install it in any position to cut small trees horizontal, upside down to cut roots, etc.
Thanks JJ. Great idea!
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
(2) Firestone Tires (A65640)
(2) Firestone...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2005 DRAGON END DUMP TRAILER (A65643)
2005 DRAGON END...
2018 John Deere MX5 (A64126)
2018 John Deere...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2017 TROXELL 150...
