Boom Pole (first build)
/ Boom Pole (first build) #1
petergreen
Member
Spain, Europe.
Lamborghini R1.40
Hello friends!
I'm new to welding. I learned just a few months ago, and I just finished my first "serious" build: a boom pole.
What do you think? I designed the thing myself, just looking for photos that people upload to the internet.
I've tested the thing by lifting my tiller (It weighs about 200kg, I think). It seems to hold. I'm happy!!!
/ Boom Pole (first build) #3
Peter;
Nice build but, you should look into rated lifting slings or chains.
Thanks for sharing.
Peter;
Thanks for sharing.
Yes, those belts got some beating that day. I have a heavy-duty chain for lifting work now. Better safe than sorry!!
/ Boom Pole (first build) #6
Looks very strong. To really test it chain it to an immovable object and max the 3 point capacity. Bet it will take it.
/ Boom Pole (first build) #7
Actually, I think the boom will bend at the point of the braces with a heavy load, or where the hole is in the side of the boom with a hanger..
What you need is a back bone setup where you add a 6 in riser at the brace point. Then a section of rebar from the 3pt pin across the 6 in riser and then on to the tip.
Is the tubing 1/16 in or 1/4 in?
Like this maybe.
Like this maybe.
Thanks, J_J, for your suggestions. I'll do that. Tube is 5cm (diameter).
/ Boom Pole (first build) #12
For those that don't know. 5cm = 131⁄32in
What is the wall thickness?
A good boom should be at least 2 in tubing or more and 1/4 in wall thickness.
1/4in = 41⁄64cm
2in = 5.0800cm
1/4in = 41⁄64cm
2in = 5.0800cm
I think thickness is 4 - 5 mm (1/4inch =~ 0.6mm)
/ Boom Pole (first build) #14
Actually, I think the boom will bend at the point of the braces with a heavy load, or where the hole is in the side of the boom with a hanger.. What you need is a back bone setup where you add a 6 in riser at the brace point. Then a section of rebar from the 3pt pin across the 6 in riser and then on to the tip. Is the tubing 1/16 in or 1/4 in? Like this maybe.
JJ;
What is the device, on the end of the boom, in your picture?
Thanks
/ Boom Pole (first build) #15
Hello friends!
Nice build!! Would make loading your tiller onto a trailer or anything else easy. I'm impressed with how it looks
/ Boom Pole (first build) #18
The attachment on the end of my boom is a tree snipper, limb snipper, limb cutter. etc..
Can reach up about 16 ft.
I can install it in any position to cut small trees horizontal, upside down to cut roots, etc.
/ Boom Pole (first build) #19
The attachment on the end of my boom is a tree snipper, limb snipper, limb cutter. etc.. Can reach up about 16 ft. I can install it in any position to cut small trees horizontal, upside down to cut roots, etc.
Thanks JJ. Great idea!
UNUSED RAYTREE RMLL60 - 60" POWER RAKE LAND LEVEL (A62131)
UNUSED RAYTREE...
2014 Dodge Charger Sedan (A61569)
2014 Dodge Charger...
Horse Weathervane (A61569)
Horse Weathervane...
2023 Kubota KX057-5 Compact Excavator (A63118)
2023 Kubota...
2010 FORD F-150 XL CREW CAB TRUCK (A62130)
2010 FORD F-150 XL...
UNUSED ATS ME18 MINI EXCAVATOR (A62130)
UNUSED ATS ME18...
