Bobcat S185 17-07 error code
/ Bobcat S185 17-07 error code #1
KellygC
Bagley, Mn
Bobcat s185
Skidsteer stopped running while idling. Wouldn't restart, "input" displayed in hour meter. Later code of 17-07 came up. Cleaned all grounds, checked main wire harness connections for corrosion(none found). All fuses and relay check out ok. HELP!
/ Bobcat S185 17-07 error code #2
The code is hydraulic lock solenoid open circuit in case you haven't already looked that up somewhere. Hopefully Dennis (SSdoxie) will see your post and give a reply. He's the Bobcat guy on this forum.
/ Bobcat S185 17-07 error code #3
Code means lost communication between main controller and left panel or right Deluxe (keyless panel) if equipped. Communication wires are numbered4 digits and all start with 91. Go to back of each panel and main controller (located in left front fender area). check and wiggle plug connections to see if disappears. If it does remove the connections, clean and apply light coat of dialectic grease.
Also check these wires for continuity of short to ground and/or power. There should be no connection to ground or power with power OFF.
2016 MACK PINNACLE (A63569)
2016 MACK PINNACLE...
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59912)
2025 PJ CC162 T/A...
SET OF (9) CENTRIFUGAL PUMPS (A63569)
SET OF (9)...
2012 Chevrolet 3500 HD Dually (A64047)
2012 Chevrolet...
2008 DOOSAN G25 GENERATOR (A63569)
2008 DOOSAN G25...
1995 John Deere 5200 45HP 4x4 Utility Tractor (A61572)
1995 John Deere...
