laurencen
Veteran Member
- Joined
- Feb 19, 2007
- Messages
- 1,210
- Location
- saskatchewan Canada
- Tractor
- Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
my Bobcat E32 has the GPS locator, if stolen or something is not working right the dealer can locate it and relay codes, problem I am having the battery is dead if not used 6 to 8 weeks, its sending a signal 23-7-52, want to have it powered when the ignition is powered up.
Dealer has no help as to where its located or how its powered, first off what does it look like? there is what I believe is the antenna mounted under the side cover (fiberglass) above the fuse box, 2 black wires go into the cab after that dealer figures take inside if cab apart.
I would put a disconnect on the battery but its buried in the machine no way to get to it without taking covers off
anyone familar with this system
