bobcat for clearing brush??
/ bobcat for clearing brush?? #1
pi71
How good is a bobcat with a bucket/teeth at clearing small brush small trees. i live in bandera tx and will be renting one this weekend. Also can anyone give me any pointers on the best method on tree removal or techniques.. thanks a mill.
thanks
/ bobcat for clearing brush?? #3
You're welcome... /forums/images/graemlins/crazy.gif
Can't answer your questions regarding the skid steer, but you might try searching the archives for Bobcat or Skid steer...there have been some posts in the past addressing similar issues...
/ bobcat for clearing brush?? #4
They work great.
For brush, I pull up close to the overgrown area with the bucket raised then lower it and put the bucket in float. Then backup and the teeth grab into the brush and it pulls out the brush very easily. Depending on the amount to remove, it may take a couple runs of this fashion.
Small trees that won't push/pull over usually need to be loosened by digging them out.
I usually drag the brush out and then after I get a section cleared, push all the removed brush together into a larger pile. You can push a very large pile to a central location if you need to.
You will be amazed how much brush you can clear with a skidsteer in a couple hours.
/ bobcat for clearing brush?? #5
I can only add that a Bobcat, even when carefully used, can and will tare up your land. They are great on construction sites though.
Mark
/ bobcat for clearing brush?? #6
If you push with the bcat, be sure to wear protective hat and shield or at least safety glasses. That stuff can flip back and you aren't very far from it.
I'd try not to dig initially, but push it at ground level. Then you can come back and dig out any of the offending hard ones.
Ron
/ bobcat for clearing brush?? #7
<font color="blue"> I can only add that a Bobcat, even when carefully used, can and will tare up your land. </font>
Yes, they do rip up the grass pretty good, especially when turning tightly. What I do after I get a section cleared is go back and use the float on the bucket to smooth out the area you worked in.
Here is a Before/After shot of some large multi-flora rose bushes I removed along the road.
/ bobcat for clearing brush?? #8
Yes, that is why there are many offerings of "tracked" units now, from Bobcat, CAT, ASVi, and others. Work really well, and do not tear things as much as a typical skidsteer. Bobcat also offers a 4-wheel steer unit, which can operate either in standard skidsteer mode, or 4-wheel steer.
I have used the CAT and ASVi units. The tractor rides much better than a standard skidsteer. It is much easier on the ground, even when turning; the PSI of the wheel on a skid-steer vs the track is amazingly different.
8" Mini Excavator Bucket (A66285)
8" Mini Excavator...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
2014 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A61573)
2014 Chevrolet...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
CAT CB34 (A60462)
CAT CB34 (A60462)
