Bobcat CT235 3 Point Hitch
/ Bobcat CT235 3 Point Hitch #1
bbweeks
Pa
Deutz 5230/Bobcat CK235hst
I just installed a double rear aux hydraulic kit on my bobcat and now the 3 point will not raise- it is completely in down position. Any idea what I need to do. I did not do any adjusting on the hydraulic kits.
/ Bobcat CT235 3 Point Hitch #2
Are both of the new Selective control valves you just installed in the neutral position? The open center fluid flow is thu those valves on the way to the 3pt, and it now looks like the 3pt is no longer getting the fluid flow for one reason or another. Some of the valves have a detented position. Is it possible that one of the valves is in detent?
/ Bobcat CT235 3 Point Hitch #3
If those valves are not centered the 3 point will not go up.
I did check that the new valve are centered,also tried moving both valves thru their entire stroke several times. I'm wondering if a damaged o ring could be the cause. I had trouble installing 3 of the 4 hard lines from the valve to the rear bracket as they were off as much as 2 inches and had to be reshape in order to fit properly. I'm thinking of dissembling everything to check the O rings, don't know where else to start looking.
/ Bobcat CT235 3 Point Hitch #5
Do the new hydraulic outlets work?
Good question, I don't know and I do not have any way to test them. I mounted a 7 ft Meyers snow blade to a quick attach plate this summer and am planning to run the hydraulic angle cylinders off the auxiliaries but still need to run the lines to the front. I may be able to borrow a cylinder and lines for a test, is there any other way to test. I really do not know much about hydraulics. Do you think a damaged or missing O ring could be the cause of my problem.
/ Bobcat CT235 3 Point Hitch #7
A pressure gauge on a connector or a hose into a bucket or into the fill hole of the reservoir would work.
Not sure about the O ring, but doubt that is the problem.
/ Bobcat CT235 3 Point Hitch #8
If the o rings are on the work port lines it would just leak. Bending hard lines from a oem kit doesn't sound right.
/ Bobcat CT235 3 Point Hitch #9
I had the 3 point on my CT-445 stop working like this. Turned out a piece of debris in the 3 point valve was preventing it from working. Tractor had just over 100 hours.
Thanks for the suggestions they do give me some direction. As soon as I get back to working on my tractor, probably next year I'll check to see if the auxiliarys are working. When installing, the first hard line fit perfectly but the next three needed adjustment, I'm now thinking I need to go back and check if my dealer sold me the correct kit, don't know if one kit fits multiple tractors. I'll let you all know what I find.
Good news everyone, the 3 point is now working. I took Xfaxman's advice and had a short hose made to test the aux. outputs- none were getting oil so I decided to start over and removed the seat, right counsel and all hard lines and valves to starting point. It occurred to me that maybe the cover plate which was the first thing removed before starting the install could be installed incorrectly and guess what, it was rotated 180 degrees which prevented the fluid from flowing thru. I reassembled everything and now have a working 3 point hitch and all 4 aux's are getting oil. Wish the directions would have mentioned being careful to reinstall the cover plate in the same position as removed. Well that's what happens when a old retired electrician starts messing with hydraulics. Thanks for all of your suggestions, they were what set me in the right direction . Now on to running hoses to the front for my snow plow blade angle cylinders.
/ Bobcat CT235 3 Point Hitch #12
Congratulations! Good work. :thumbsup:
/ Bobcat CT235 3 Point Hitch #13
If you need help on running the hoses to the front, search my user name as I went through this last year. Brian at Fit Right Hydraulics can set you up with a complete kit too. Hope this helps.
/ Bobcat CT235 3 Point Hitch #14
(15) UNUSED 8'X41' PROTECTION MATS (A60432)
(15) UNUSED 8'X41'...
2012 BOBCAT T650 SKID STEER (A60429)
2012 BOBCAT T650...
2015 Adams Tender Trailer (A61306)
2015 Adams Tender...
2025 BOBCAT ZT7000 MOWER (A59905)
2025 BOBCAT ZT7000...
UNUSED KJ K0720-7'X20' METAL FARM DRIVEWAY GATE (A60432)
UNUSED KJ...
JOHN DEERE 3032E TRACTOR (A60430)
JOHN DEERE 3032E...
