Bobcat CT235 3 Point Hitch
   / Bobcat CT235 3 Point Hitch
Good news everyone, the 3 point is now working. I took Xfaxman's advice and had a short hose made to test the aux. outputs- none were getting oil so I decided to start over and removed the seat, right counsel and all hard lines and valves to starting point. It occurred to me that maybe the cover plate which was the first thing removed before starting the install could be installed incorrectly and guess what, it was rotated 180 degrees which prevented the fluid from flowing thru. I reassembled everything and now have a working 3 point hitch and all 4 aux's are getting oil. Wish the directions would have mentioned being careful to reinstall the cover plate in the same position as removed. Well that's what happens when a old retired electrician starts messing with hydraulics. Thanks for all of your suggestions, they were what set me in the right direction . Now on to running hoses to the front for my snow plow blade angle cylinders.
   / Bobcat CT235 3 Point Hitch #12
Congratulations! Good work. :thumbsup:
   / Bobcat CT235 3 Point Hitch #13
If you need help on running the hoses to the front, search my user name as I went through this last year. Brian at Fit Right Hydraulics can set you up with a complete kit too. Hope this helps.
   / Bobcat CT235 3 Point Hitch #14
iDrive TDS-2010H...
2024 MECO M-Y 4-Passenger Electric Car (A59231)
2024 MECO M-Y...
CAT 930M (A58214)
CAT 930M (A58214)
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
2003 Big Tex 10PI...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
